That would work, but what I've always done is pull the fuel pump relay and crank the car over a few times.
You'll need a flathead screwdriver for the clips and some oil for the o-rings if they are dry (they install easily when lubricated with a slight coat of oil).
You car has Bosch L-Jetronic fuel injection. It is very sensitive to vacuum leaks. check for hardened hoses and replace as necessary. A factory service manual is available somewhere, I'll try to find the link.
