FS: Interior light delay module
  • Fusion
    • Nov 2009
    • 3659
    FS: Interior light delay module for E30, E28, possibly other models. Direct drop in replacement for the factory delay relay. This module fades in, delays, fades out like modern BMWs since about 1999.
    - User selectable fade-in speed, delay time, fade out speed, each approx. 30 seconds max
    - Turning the ignition to Start cancels delay and triggers fade-out
    - Double ignition turn to Start turns lighting on, regardless of door state
    - Does not turn on at all under 11V (ie. door left open, to eliminate drain from interior lights)
    - Does not require any wire harness modification
    - Can be covered by a BMW relay cover, but has conformal coating
    $40 incl. shipping to anywhere in the world
    PayPal accepted​
    Click image for larger version  Name:	IMG_7928.jpg Views:	518 Size:	190.0 KB ID:	10095118
    Click image for larger version  Name:	IMG_7941.jpg Views:	465 Size:	182.2 KB ID:	10095119
  • flipper325es
    • Aug 2009
    • 280
    Cool! Are the 3 Phillips screw heads the delay adjusters?
    Now I have to open the ETM and find the E30 delay relay location :-)
    • Fusion
      • Nov 2009
      • 3659
      Thanks! That's correct, but a small flathead is required to turn the trimmers.
      The relay is right behind the driver's side kick panel, behind the speaker, clipped on a mount for the central locking module.
      • flipper325es
        • Aug 2009
        • 280
        Got it, thanks! Now I just need to finish (well, first start, then finish) the suspension refresh, and get the car off the jack stands. In the meantime, I'll look for another relay to salvage the housing, so I wouldn't have to take mine apart. No doubt your relay can be easily fixtured in place as-is, but the OE housing looks to have clips for seamless installation.
        • cdl723
          • Jan 2015
          • 144
          I pm'd you. Do you have another one I could buy?
          • Fusion
            • Nov 2009
            • 3659
            PM'd.
            For anyone else interested, I have about 3 more available in this run. Going quick!
            • Fusion
              • Nov 2009
              • 3659
              Bumpity bump
              • Fusion
                • Nov 2009
                • 3659
                New batch ready for anyone interested.
                • Simple_Smith
                  • Aug 2011
                  • 585
                  this is excellent. I definitely need to pick up one of these.
                  1989 JDM-Tech 2
                  2010 335 D for daily
                  • Fusion
                    • Nov 2009
                    • 3659
                    Bump
                    • Fusion
                      • Nov 2009
                      • 3659
                      Still some available from the last batch. Hit me up if interested!
                      • Fusion
                        • Nov 2009
                        • 3659
                        New batch came in.
                        Had a few questions about LED bulbs. This module works great with them.
                        • Fusion
                          • Nov 2009
                          • 3659
                          • Fusion
                            • Nov 2009
                            • 3659
                            Current batch running out, but still have a few ready to ship.
                            • moatilliatta
                              • 6158
                              In PMd
                              @Zakspeed_US
