FS- Front Door Reinforcement Plates
  • Pottsalot
    • Nov 2011
    • 387
    Inventory is out folks. May cut another batch in the near future.
    Ive had a few people ask if I sale these plates, I finally got some measurements and sketched a blueprint. These are cut from 11g grade 50 HRPO steel. Bolt on, no welding required.
    If you are experiencing creaking or popping if you front doors, you might be a victim. Fix the issue before it tears and bends your door hinge,brake in.
    Please include your username in the message when sending money. Thanks
  • Cletonius
    • 2809
    Where do these mount? Inside the door?
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • FLG
      • Sep 2011
      • 3165
      Yep how do they mount/work? My front doors make some noise when i go over bumps, or is that a completely different problem?
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • Blaine0002
        • 382
        if you make a piece like this for the door prop, i will buy it.
        • Pottsalot
          • Nov 2011
          • 387
          These plates are held in place by the 2 door brake bolts. You will need to take the pin out of the door hinge and slide this through it.
          Sent from my DROID2 using Tapatalk 2
          • Pottsalot
            • Nov 2011
            • 387
            Not sure of your issue,you will have to pull the rubber cover back and inspect the metal around the door brake.
            • thebutcher37
              • 2877
              Might need these..
              but not sure of how they work?
              Any installed photos or anything else. Thanks.
              Transaction Feedback
              • Beach Bum
                • 466
                I'll take a pair. How do I pay you?
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • Pottsalot
                  • Nov 2011
                  • 387
                  Originally posted by thebutcher37
                  Might need these..
                  I will get you some installed photos this weekend
                  • Pottsalot
                    • Nov 2011
                    • 387
                    Pm sent
                    • nyChris
                      • Apr 2012
                      • 395
                      My issue is when I open the door I get a violent pop noise in the hinge. Is this designed to remedy this issue? If so how does it work? I would also like to see pictures of this installed as well.. very interested
                      • Holland
                        • Nov 2008
                        • 7176
                        I thought the E34 only had this issue?
                        Originally posted by DEV0 E30
                        • bubbajan21
                          • 1962
                          I'm also interested in more info on what these do / how they work.
                          • ÜberslowETA
                            • 190
                            When I bought my car the sheet metal that holds the hinge was torn and I hadnt noticed. My window ended up shattering one day after I closed my door and the hinge happen to be in the right position. These could have saved me a lot of trouble. GLWS.
                            • nebulous123
                              • Jun 2011
                              • 923
                              yeah in for pics
                              '84 325e - "Elizabeth"
                              '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
