I can clean your fuel injectors. Just pay for shipping and the fluid
  • MEPEH
    • Aug 2012
    • 399
    #346
    Originally posted by jwal
    I just checked out the site. Do you have any idea when you will have more 4 pintle m42 injectors? ;D
    Is this what you are looking for ?
    Part Number 0280155700 Mustang Yellow injectors ?
    I may be able to get it but It will take about 10 days to get you this order.
    I will PM you a discount code for these injectors so you could get them for 10$ a piece, plus shipping (6$ to US/25$ international)
    Let me know if you're still interested and i'll start ordering stock.
    Get your Injectors Cleaned HERE
    • MEPEH
      • Aug 2012
      • 399
      #347
      Originally posted by Cayoncrusier93
      Coupon code doesn't seem to be working for me?
      PM'ed
      Please only use the coupon if you check out as a guest.
      No need to waste your time registering an account (unless you plan on shopping with me a lot :)
      • jwal
        • Apr 2014
        • 385
        #348
        I think those are right...I have seen a ton of part numbers for these injectors.
        My injectors are Part Number 0280150714 which are listed as 200 cc/min and 15.9 ohms of resistance here: http://www.injectorcleaning.co.uk/flow.htm
        The part number you provided have the same flowrate, but a resistance of 14.5. Would this cause an issue?
        • MEPEH
          • Aug 2012
          • 399
          #349
          They will work as replacement for your 714 injectors.
          The resistance will not matter, it's plug and play (drive)
          • mpowerful
            • Jul 2013
            • 1273
            #350
            280155700 and 280155710 are exactly same gen 3 bosch. Great 19lb 4 hole injectors!
            • jwal
              • Apr 2014
              • 385
              #351
              Here are some part numbers, cc/min@3 bar flowrates and ohm resistance values that should be compatible with the m42. Its a long list :P
              0280150413 205 15.9
              0280150421 200 15.9
              0280150428 205 15.9
              0280150429 205 15.9
              0280150454 199 15.9
              0280150456 199 15.9
              0280150463 199 15.9
              0280150500 200 15.9
              0280150501 200 15.9
              0280150503 200 15.9
              0280150505 200 15.9
              0280150509 199 15.9
              0280150560 200 15.9
              0280150702 200 15.9
              0280150704 200 15.9
              0280150707 200 15.9
              0280150711 200 15.9
              0280150714 200 15.9
              0280150721 200 15.9
              0280150722 200 15.9
              0280150725 200 15.9
              0280150729 200 15.9
              0280150730 201 15.9
              0280150731 201 15.9
              0280150734 200 15.9
              0280150736 199 15.9
              0280150741 200 15.9
              0280150743 200 15.9
              0280150747 200 15.9
              0280150751 200 15.9
              0280150757 200 15.9
              0280150760 200 15.9
              0280150762 200 15.9
              0280150764 200 15.9
              0280150766 200 15.9
              0280150769 200 15.9
              0280150776 200 15.9
              0280150779 200 15.9
              0280150783 200 15.9
              0280150790 199 15.9
              0280150902 205 15.9
              0280150903 205 15.9
              0280150931 200 15.9
              0280150953 196 15.9
              0280150954 196 15.9
              0280150962 200 15.9
              0280150976 200 15.9
              0280150977 205 15.9
              0280150978 205 15.9
              0280150979 215 15.9
              0280150980 215 15.9
              0280150983 200 15.9
              • mpowerful
                • Jul 2013
                • 1273
                #352
                The body sizes and clip types do differ so id imagine that out of that list only a few might actually work. All of those are single pintle gen1s as well which basically suck.
                • jwal
                  • Apr 2014
                  • 385
                  #353
                  Hmmmm ok, I believe you haha. I just cross referenced them from the list here: http://www.injectorcleaning.co.uk/flow.htm
                  I guess its outdated. If you dont mind me asking, why does the resistance not need to match the original injectors?
                  • xcx4x
                    • Sep 2013
                    • 184
                    #354
                    how many do i need?
                    how much for a new set?
                    • mpowerful
                      • Jul 2013
                      • 1273
                      #355
                      Because the resistance refers to the resistance of the motor at 12v. The drivers that run the injectors are blind to that resistance so long as its within the range at which the driver can supply the current. That system uses high resistance which requires very low current. The system can tolerate say .5amps to 1 amp reliably which means it can basically use any high impedence injector 12-16ohms.
                      • dewme5
                        • Mar 2014
                        • 165
                        #356
                        Another satisfied customer. Ordered from mpowerful last week, and they were shipped immediately, and the results are a much smoother idling m20, with more power. Well worth the money I paid.
                        • MEPEH
                          • Aug 2012
                          • 399
                          #357
                          I finally got the famous Ford Yellow injectors
                          0280150700 and 0280155710
                          M42 Engine upgrade option :)
                          I have 4 sets available ATM and can sell them @ 40$ for a set of 4 Shipped to US, rebuilt with 1 year warranty... or an extra 25$ to ship Worldwide
                          • jwal
                            • Apr 2014
                            • 385
                            #358
                            I have 4 sets available ATM and can sell them @ 60$ for a set of 6 Shipped to US, rebuilt with 1 year warranty... or an extra 25$ to ship Worldwide
                            Are these also compatible with the m42? If so I'll buy some now!
                            • MEPEH
                              • Aug 2012
                              • 399
                              #359
                              Yes, you can read more info here
                              http://forums.bimmerforums.com/forum...ors-Are-Awsome!
                              • AndrewBird
                                The Mad Scientist
                                • 11892
                                #360
                                Just placed an order to have some injectors cleaned. Thank you SO MUCH for offering this service. You won't find a better deal anywhere.
