M30 Conversion Parts
  • rs4pro3
    • 5808
    Well I need some cash so these are for sale
    E30.de Type 1 engine mounts, these are for all pre 88 M30 engines, to bolt them into position 2 or 3 in an e30, These were purchased brand new from Tino, painted black, then used for about 6 months untill my engine died, in great shape, like new.-SOLD
    E34 535i Oil pan, had a crack but was profesionally welded, no leaks at all, includes longer bolts needed for the rear-$85 shipped
    E34 535i Oil pump, great shape under 100k miles-SOLD
    E32 140amp Alternator, great if you have a high power stereo system, rebuilt with 10k miles on it-$80 shipped
    E34 B35 Intake manifold, cleaned and painted,
    $60 shipped
    E34 B35 Painted Valve cover
    $50 shipped
    85 325e 2.7 ITB'd stroker
  • rs4pro3
    • 5808
    Bump
    • rs4pro3
      • 5808
      Few more items
      custom Motronic 1.3 conversion engine harness for the m30 swap, direct plug and play for 88 and newer e30's, included main harness, fuel injector harness, fuel rail harness cover and brackets-$100 shipped
      E34 high power started-$90 shipped
      E34 Spark Plug wire set with #6 sensor-$80 shipped
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        Have you completely given up on another 3.5 swap?
        • rs4pro3
          • 5808
          for the time being yes
          • bmwmike
            • Sep 2004
            • 561
            did you say you blew the m30? Howd you do that? (and it was n/a correct?)
            www.rimstrader.com
            all the parts you need to swap the M30 into your E30 here-> http://www.r3vlimited.com/board/show...ght=m30+mounts
            99 540i/66 911
            • rs4pro3
              • 5808
              correct, N/A engine, brand new water pump belt snapped while doing 80 on the interstate, by the time I noticed the guage peg red, the engine had overheated, and lost compression and had horid leakdown numbers.
              • RobertK
                • Jun 2005
                • 5864
                I recently got some more new tools in prepping for an engine rebuild in the shop at my house. I also got a heavy duty engine stand and I'm about to pick up a 1 ton engine hoist soon. So if you want to rebuild that bad boy Josh and I could possible help out. We're looking for the experience.
                Otherwise we're looking for a cheap M20B25 or M50 to blueprint and rebuild.
                • X2theZ3
                  • Mar 2004
                  • 932
                  Wow, a direct plug and play harness for 100 bucks.
                  Someone needs to jump on that.
                  • bmwmike
                    • Sep 2004
                    • 561
                    if you have anything else for the swap let me know.
                    www.rimstrader.com
                    99 540i/66 911
                    • rs4pro3
                      • 5808
                      I have a lot, what do you need.
                      • bmwmike
                        • Sep 2004
                        • 561
                        hmm, well i have:
                        86 e28 M30
                        E34 oil pan and pump (thanks!)
                        Engine mounts (thanks again)
                        e28 Trans
                        e28 diff
                        e28 radiator
                        e28 ecu and wiring (and keep in mind Ill be doing turbo with megasquirt)
                        e28 engine accesories
                        hmm do you have the driveshaft, but keep in mind Id need it to link the M30 engine/trans with the E28 diff (im not sure what diff you used).
                        what else would I need here? let me know prices too
                        www.rimstrader.com
                        99 540i/66 911
                        • rs4pro3
                          • 5808
                          I'm ussing the driveshaft in my car currently(I like the larger guibo), the E28 diff uses the same flange bolt pattern as the e30, so no worries there.
                          I realy can't think of anything else you may need.
                          • bmwmike
                            • Sep 2004
                            • 561
                            and actually i have the e28 d-shaft too, so ill figure it out. thanks
                            www.rimstrader.com
                            99 540i/66 911
                            • parkerbink
                              • Jun 2004
                              • 10138
                              The alternator is plug & play to a 90 e30 325ic?
                              If so I'll take it.
