FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
  • Max399
    • Feb 2013
    • 991
    #361
    Bump
    5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
    Leave feedback about my transactions!
    • Max399
      • Feb 2013
      • 991
      #362
      Bump
      • ninjaotter
        • Nov 2009
        • 455
        #363
        Marked for later...
        • JoeyE30
          • Feb 2017
          • 1
          #364
          PM Sent
          • Kobra
            • Feb 2017
            • 5
            #365
            Message sent, very keen.
            • Max399
              • Feb 2013
              • 991
              #366
              Bump.
              • Max399
                • Feb 2013
                • 991
                #367
                Bump
                • stanhayward
                  • Mar 2013
                  • 765
                  #368
                  Can you fit 16" wheels over 300mm E46 rotors with E38 calipers? Am trying to plan out what will work for me. TIA!
                  1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
                  1984 316 Coupe - The Base Model - Pain in the Ass
                  1988 750iL - The Daily Driver
                  ...And a couple others...
                  • kventis
                    • Mar 2017
                    • 1
                    #369
                    Are you still selling these? Check your inbox mate, I really need a set 318ti discs -> e46 330
                    • LowR3V'in
                      • 4209
                      #370
                      I'm just waiting till I get my car rolling soon then buy these :x
                      • WellMax
                        • Apr 2017
                        • 8
                        #371
                        Quote: As for the disk trailing arms (TI), there are also 2 variants, one is a bracket that allows you to mount rear E46 M3 brakes on the TI trailing arms and the other is a bracket to allow you to mount any E36/E46 rear caliper and rotor.
                        I want to upgrade my brakes and be able to use 15" e36 bottle caps.
                        to do that I can only use non M e36 calipers and rotors, I know with max339's kit for the front i can use the e36 bottle caps. what about the rear kit?
                        Are you guys SURE this kit will allow an e36 rear caliper and rotor to be installed... There is one part that says any e36 rear caliper & rotor, and then there is a part that just mentions e46.
                        BTW I would love to be able to use the e30 bottle cap rims.... Does any one know of upgrading at least the front brakes with bigger rotors and calipers and still keep the e30 bottle cap rims on?
                        • Max399
                          • Feb 2013
                          • 991
                          #372
                          With the front setup being 5-lug, you and E36/5 rear trailing arms - you already have good brakes and 5-lug on all 4 corners.
                          My rear kit is considered a big brake kit. Most of the people who got it ended up using E46 330 rear brakes, which are pretty massive. It might and should work with other E36 and E46 calipers - but since all of the people who got it used in on E46 330 - dont put my word on it :)
                          Also with that rear kit - you will loose the parking brake, since the rotor has a different offset.
                          As for bottle caps - there were no 5-lug ones, just the E36 ones.
                          Max
                          • Max399
                            • Feb 2013
                            • 991
                            #373
                            Bump! Kits available and in stock
                            • erike30
                              • Jan 2017
                              • 2
                              #374
                              Hi maxx, If i would buy the dual caliper setup for the rear, which disks I require ? and does e46 318d calipers fit ??
                              • Max399
                                • Feb 2013
                                • 991
                                #375
                                E46 330 disks and calipers :)
