Bump
FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
Update! Rear adapters available!Comment
To the skies :)Comment
do you have pics of rear installation with e36/e46 non M on e30 disc trailing arm?[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction FeedbackComment
Hello, no, currently i do not.
Max.Comment
BumpComment
Yes, all adapters are for E36/5 trailing arms. Disk or drum.Comment
E46/E36 ones.Comment
If you go with the drum traling arms and covert them to single or dual caliper setup - then no parking brake. But if you go with the disk trailing arms from a TI - you can convert those to bigger brakes and keep the parking brake.
Max.Comment
- What else do i need to finish the swap for the front?
To finish the swap you would need E36 or E46 hub assembly, rotors and calipers with carriers.
Brake pads of course.Comment
I have just called the manifacturer and asked him to confirm or deny it. He told it is possible and that he will check and message me if anything needs to be modified.
He told that the adapter is the same as 300mm.de and that they do get a working parking brake. Will reply on that once i get a call back.
Max.Comment
Max.
this is because the 318ti rotor is MUCH taller than any e46 rear rotors:
