FS: 5-lug Kit | E36 & E46 Hub & Caliper Adapters for E30! | Rear Big Brake Kit
  • Max399
    • Feb 2013
    • 991
    #121
    Yes, but as you can see the 300mm.de rear adapters are not raised:
    They are flat, where as the ones i offer are raised:
    They move the calipers towards the rotor.
    5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
    Leave feedback about my transactions!
    • Max399
      • Feb 2013
      • 991
      #122
      Here is a better view of the 300mm.de adapter for the rear:
      • Julien
        • 7471
        #123
        Originally posted by 300mm.de
        When using the Compact hubs can the brake discs from the E85 Z4 2.5si with dimensions 294x19mm (Part Number: 34 21 6,766,219) together with the adapter 294-3 and the rear calipers from the E32 750i, E34 540i, E36 M3 installed. 5mm washers are between the adapter and saddle pickup to mount (washers and Quick Start Guide are included).
        Build Threads:
        • Max399
          • Feb 2013
          • 991
          #124
          I see what you mean mate, but still they are different, the adapters i offer allow normal E36/E46 rotors and calipers to be used.
          • Julien
            • 7471
            #125
            What I'm saying is that it's impossible to use a 318ti trailing arm/hub/ebrake with a non ti (or z4) disk and still retain e-brake without swapping to a non TI hub
            Build Threads:
            • ngampleh
              • Jul 2012
              • 466
              #126
              How to install ur rear bracket?
              Is that after mounting that bracket than caliper, or what?
              No pics of it, how you make sure that your rear bracket bolt on?
              [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
              [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
              Transaction Feedback
              • Max399
                • Feb 2013
                • 991
                #127
                I do not have any pictures of it being mounted, so you will have to believe me that it fits. It has been tested and is being actively used here by our drift teams.
                You bolt that to your stock caliper location, and then the new caliper bolts to this bracket.
                Max.
                • e30m3s54turbo
                  • Jun 2010
                  • 3210
                  #128
                  Hi Max.
                  On the rear adapters is a great deal. Later this year I will order some more adapter from you again. It is easy doing business with you.:p
                  Last year I bought 300mm De. adapters for $325. I had to file claim on Tino. He said my email was in the junk email. It was resolved.
                  • Max399
                    • Feb 2013
                    • 991
                    #129
                    Thanks mate, was pleasure dealing with you too.
                    Im still waiting for the reply on the handbrake issue, will reply once i get an answer.
                    Max.
                    • ngampleh
                      • Jul 2012
                      • 466
                      #130
                      How much it cost to ship front kit to Indonesia?
                      • Max399
                        • Feb 2013
                        • 991
                        #131
                        60$ is shipping to Indonesia.
                        Max.
                        • ngampleh
                          • Jul 2012
                          • 466
                          #132
                          Max.
                          Is that thru Lithuania Post or what?
                          • Max399
                            • Feb 2013
                            • 991
                            #133
                            Yes, that is through Lithuania Post.
                            The shipping is by Air Mail and Tracked.
                            Max.
                            • strang3majik
                              • Aug 2012
                              • 310
                              #134
                              I'm confused on what exactly the rear adapters are for. I have an 84 318i e30 that has drums that I want to convert to 5 lug discs...
                              I have a set of e30 disc brake trailing arms. What are these adapters for? Do they bolt to e30 trailing arms and allow the use of e36 calipers and e36 hubs?
                              I'm wanting to do the front as well, but I understand that part. After driving my e46 m3..I've found the e30 is severely lacking in brakes. Lol.
                              • Max399
                                • Feb 2013
                                • 991
                                #135
                                The rear adapters are made for an E36/5 trailing arms. There's an option for the drum E36/5 trailing arms and disk E36/5 trailing arms. There are no adapters for the E30 trailing arms.
                                The front is pretty straight forward, yes.
                                Thank you,
                                Max.
