5 Lug AND Big Brake Kit (BBK)
    Run authentic BMW brake parts AND swap to 5x120 bolt pattern using this system of precision machined spacers and adapters! Previously available only in a group buy, now available any time! These parts will let you run E46M3 and E39 540i brakes on your E30, with OEM 5x120 drive flanges. This kit includes all spacers and hardware, along with the OEM part numbers needed to complete the kit. Full picture instructions are also included to answer any and all questions. I have become very familiar with this kit and installed these parts myself on my 91 318is. These are significantly bigger rotors and calipers
    Rear on my 318is:
    Front:
    All parts are professionally machined in the USA using the following materials:
    Front Hub Bushings- 4043 Chrome-moly steel
    Front Hub Nuts- 4043 Chrome-moly steel
    Front Caliper Brackets- 2024 Aluminum
    Rotor Spacers- 6061 Aluminum
    Rotor Centering Rings- 6061 Aluminum
    Hub Centric Retainers- 6061 Aluminum
    Rear Caliper Brackets- 2024 Aluminum
    Previous kits have been shipped to Germany where they have passed the rigorous TÜV standards. Installation is as easy as replacing a wheel bearing, and retains the stock E30 suspension geometry, unlike swapping trailing arms etc. Shoot me a PM if you have any questions!
    Price for the kit shipped to your door including PayPal fees is $450.
    The Lineup in order of appearance:
    91 535i
    91 318is 5 Lug/E46M3 Brakes
    91 325is w/ S52
    88 Vert Plastic Bumper Swap
    88 M3 ;D
    91 325ix 5 speed
    89 Vert Royalblau Metallic
    73 2002
    1986 325es --> is swap Rallycross Car!!
    1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
    1993 525i Granitsilber Metallic Touring
    Need a 91 M5 bad but wife would shoot me...twice
    *UPDATE: got a 93 M5 and still alive
    1972 Jeep Wagoneer
    1975 2002 five speed
    Check out:
    Elhartspeedshop.com
    Is this kit still made by nasieg?
    Feedback
    Instagram - @e30_mtech2
      I was wondering the same thing but I thought his kit allowed you to run E46M3 brakes in the front and rear.
        So you must run 18's to clear the brakes with this kit?
          Great Questions!
          I did establish a partnership with Nasieg, and he machines the part. I put the kit together with install instructions, all hardware needed, and information. Still the same quality he was known for.
          The kit will clear 17's with the set up I recommend, have not personally tried 16's but some R3v members have. My current set up is 17x8 all around.
          91 535i
          91 325is w/ S52
          88 M3 ;D
          91 325ix 5 speed
          73 2002
          1972 Jeep Wagoneer
          Check out:
          Elhartspeedshop.com
            Would E36 M3 calipers bolt up or I would need E46 calipers in the front? Similar question for the rear, will only E39 540i calipers fit?
              E36 M3 and E46 M3 front calipers fit. And only the e39 rear calipers fit.
                E36 M3 Calipers would work with E46 M3 rotors I believe, but I recommend E46 M3 because I know they fit from experience. According to Realoem.com the 540i calipers are common with 530i calipers. Rear rotors are from a non M E46. I include all the part numbers in the kit!
                91 535i
                91 325is w/ S52
                88 M3 ;D
                91 325ix 5 speed
                73 2002
                1972 Jeep Wagoneer
                Check out:
                Elhartspeedshop.com
                  So you can't run E46M3 calipers in the rear?
                    Correct!
                    91 535i
                    91 325is w/ S52
                    88 M3 ;D
                    91 325ix 5 speed
                    73 2002
                    1972 Jeep Wagoneer
                    Check out:
                    Elhartspeedshop.com
                      what accommodations are made to retain the e-brake ?
                        1- Will this work also with flying rotors euro E46 M3euro ?
                        2-What rotors for the rear ?
                        3-Whats your Rims offset (front & rear )
                        4-would you split the kit ? front only -rear only ?
                          Using the E46 non M rotor in the rear allows for retention of the stock E30 parking brake! Works the same as stock.
                          1-Do you mean the floating rotor?
                          2- Rears are E46 non M rotors (E46 325i etc.)
                          3- Personally I have Et15 all around just because I had those in our personal stock, but generally it is E36 fitment. I am looking for ET35 for less poke! The front gets pushed out 12mm from stock E30 location by the E36 hubs/bearings.
                          4- I dont really want to split the kit, but feel free to post here for the half you want and if you can find someone for the other half we can work something out to ship to two different people!
                          91 535i
                          91 325is w/ S52
                          88 M3 ;D
                          91 325ix 5 speed
                          73 2002
                          1972 Jeep Wagoneer
                          Check out:
                          Elhartspeedshop.com
                            Group buy?
                              I hadn't planned on a group buy, but if you had 10+ people who want to order at the same time I bet we could work something out.
                              91 535i
                              91 325is w/ S52
                              88 M3 ;D
                              91 325ix 5 speed
                              73 2002
                              1972 Jeep Wagoneer
                              Check out:
                              Elhartspeedshop.com
