Have you considered brake bias when choosing the e46m fronts and 540i rears?
5 Lug AND Big Brake Kit (BBK)
Originally posted by Wh33lhop View PostHave you considered brake bias when choosing the e46m fronts and 540i rears?
Originally posted by 95///M3 View PostWhat rear brake lines do you use?The Lineup in order of appearance:
91 535i
91 318is 5 Lug/E46M3 Brakes
91 325is w/ S52
88 Vert Plastic Bumper Swap
88 M3 ;D
91 325ix 5 speed
89 Vert Royalblau Metallic
73 2002
1986 325es --> is swap Rallycross Car!!
1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
1993 525i Granitsilber Metallic Touring
Need a 91 M5 bad but wife would shoot me...twice
*UPDATE: got a 93 M5 and still alive
1972 Jeep Wagoneer
1975 2002 five speed
Check out:
Elhartspeedshop.com
Originally posted by JOMARO View Post1-Do you mean the floating rotor?
2- Rears are E46 non M rotors (E46 325i etc.)
2- Can the rears work for any other rotors (e90 320 for example 320 mm ) ?[/QUOTE]
I believe you would need a new bracket for the front caliper to use the floating rotor.
I have not had the question about E90 rotors before, or heard of anyone trying it. I would think they wouldn't work if they are 320mm, they would be too large? The E46 325 rotors I used were 294mm x 19 mm.The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
Elcoy
With the purchase of your kit and the associated parts to complete the build, do you have an estimate price to finish?
$450 kit
Parts list $?
Don't worry about labor I will be doing myself
I'm just looking for a price range considering you could go with stock to high end parts.
Thanks
joe
E30 Oem M3 Sheet metal conversion build
http://www.r3vlimited.com/board/showthread.php?t=308422
https://instagram.com/jburnsbmw/
$450 kit
Parts list $?
Thanks
joe
Including the cost of the kit, I finished mine for about $1100 doing labor myself. If you can replace a wheel bearing you can do this install no problem. Depends on if you are doing used/new and what deals you can find. The most expensive parts can be the calipers/rotors, depending one what you go with. The most expensive part for me was the E30M3 rear drive flanges, with the best deal I found being about $330 for both. Other than that its E36 front hub assemblies, and E30 rear bearings. This is about what a one axle BBK kit is, and you get both axles and a 5 lug swap!The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
Originally posted by mike87 View Postcan you provide installation instructions?
I provide full picture instructions in the kit!
Just so people know what they are getting into I can describe the install. Its essentially replacing a wheel bearing front and rear. This can be easy or harder depending on if you have the correct tools to do it. In the front you press spacers into the E36 hub assembly with a vise and reinstall as stock. The brake dust shield must be removed or modified to fit larger calipers. The only other extra step is mounting the brackets where the stock calipers go, then mounting the new calipers to the brackets.
Hope that helps!The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
"The stock E30 front lines work, I replaced the fronts with the stock E46 lines. "
Are you saying you are using front e30 lines for the rear and for the front you are using e46 lines (front or rears?).
Please be specific.
1- which lines for front (e##, F or R)
2- which line for rear (e##, F or R)
Please be specific.
2- Stock E30 Front Lines 34321159890The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
Originally posted by Eydreeyun View PostEither set up works. Jb325is used e46 m3 front lines for the rear and e30 stock lines in the front. Or you could do what elcoy did. E46 m3 front lines and e30 front lines in the rearThe Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
I have answered some questions via PM, anyone else have questions? I can ship Saturday morning, but have a track day Sunday!The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
