m20 CP Pistons :Sachs m52 clutch kit :Rebuilt eta injectors
  • 2002tiiguy
    • Jul 2013
    • 467
    wish i had the money for the pistons, im starting to collect all the parts for my turbo build, td crank is in the garage already
    • nyChris
      • Apr 2012
      • 395
      bump
      • nyChris
        • Apr 2012
        • 395
        up to the top.
        • nyChris
          • Apr 2012
          • 395
          back in town bump.
          • nyChris
            • Apr 2012
            • 395
            bump
            • dvallis
              • Oct 2015
              • 1472
              Hey, I'm looking at buying these pistons. Did a quick check on the math:
              Crank Stroke/2 + rod length + compression height should equal deck height
              81/2 + 135 + 30.25 (1.191") = 205.75 mm
              M20 block height is 206.7 mm so the piston top is 0.95 mm below the deck and compression ratio is 7.5:1
              Seems to me you'd need custom 136mm rods to make this work.
              Comments?
              "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
              1987 E30 3L Turbo Stroker Das Beast
              2002 E39 M5
              • digger
                • Nov 2005
                • 5917
                no way you need custom rods, just take some off the deck as needed. the blocks seem to be closer to 206.2 anyway but that is immaterial
                • nyChris
                  • Apr 2012
                  • 395
                  Comments?
                  I'm almost positive the pistons are designed with a fresh decking on the block/head in mind.
                  These are a VAC shelf piston. I can give them a call to answer any questions you have.
                  You are saving $185 buying them from me. These are BRAND NEW! I literally took one piston out of the box to admire it's beauty, thats it.
                  I'll send you a PM, so I can answer any other questions you have.
                  • ethurtee
                    • Jan 2013
                    • 1989
                    OP can you tell me the operational differences between this unit and the MS3-pro? Going standalone and was advised to buy the pro...
                    • dvallis
                      • Oct 2015
                      • 1472
                      Forgot to mention I'm using an 84 mm crank. :devil: These would work PERFECTLY with 81 mm crank, 135 mm rods, M20B25 block decked 1 mm. Add 0.140" head gasket if you want lower compression for a turbo setup.
                      2002 E39 M5
                      • nyChris
                        • Apr 2012
                        • 395
                        I don't claim to be an expert, but as I understand it, the only difference is the hardware. MS3-pro uses a waterproof case, one PCB, and no ribbon cables inside. This allows it to be mounted in harsher environments.
                        You basically pay $400 for a rugged hardware design. I would say it is absolutely worth it for some applications, but the glovebox of an e30 is a stable enough environment for the original MS3/MS3X hardware.
                        • nyChris
                          • Apr 2012
                          • 395
                          bump
                          • nyChris
                            • Apr 2012
                            • 395
                            new items added.
                            • nyChris
                              • Apr 2012
                              • 395
                              bump
                              • potatomash
                                • Nov 2014
                                • 203
                                So you can run these forged pistons with standard rods? I was under the assumption if you have forged pistons you also need forged rods or it throws the balance off..
                                T U R B O - M 2 0 - B U I L D
                                M U S C C O O
