Built M20 2.5 I Engine W/alpina Headers
  • JAX S50
    • 107
    THIS WAS IN MY RED E30 325IS FOR A FEW YEARS, AND NOW I HAVE DECIDED TO DO A S50 SWAP HERE IS WHAT HAS BEEN DONE:
    WORK WAS DONE AT BENSONS PERFORMANCE MACHINE IN SANTA ANA, CALIF. DAN IS A GOOD FRIEND OF MINE AND DOES ONLY TOP QUALITY WORK THIS IS OFF THE INVOICE AT THE TIME OF PICK UP
    PORT AND POLLISH HEAD $600.00
    RECON 6 CLY BMW OVER HEAD CAM $396.00
    CLEAN BLOCK $80.00
    POLISH CRANK $48.00
    POLISH & SHOTPEEN RODS (6) $120.00
    BALANCE 6 CYL $145.20
    BORE PER HOLE W/PLATE (6) $198.00
    MILL BLOCK $132.00
    ASSEMBLE ENGINE $400.00
    MOCK UP ZERO DECK $100.00
    LIST OF THE NEW PARTS IN THE HEAD
    SCHRICK M20 288 CAMSHAFT $468.00
    SCHRICK M20 VALVE SPRING OUTER (12) $156.00
    SCHRICK M20 VALVE SPRING INNER (12) $156.00
    KORMAN RACE ROCKER ARM (12) $444.60
    VAC MOTORSPORTS TITANIUM VALVE RETAINERS $189.95
    OEM ROCKER SHAFTS (2) $120.00
    BMP HEAT TREATED KEEPERS $60.00
    TRW INT VALVES (6) $138.00
    TRW EXH VALVES (6) $288.00
    LIST OF NEW PARTS IN THE BLOCK
    OEM OIL PUMP $152.00
    STD MAIN BEARING SET $150.00
    STD ROD BEARING SET $120.00
    9.8:1 EURO MAHLE I PISTONS 84.50mm $1050.00
    ALL NEW GASKETS
    FORD 19# INJECTORS
    STOCK INTAKE MANIFOLD AND THROTTLE BODY
    ALPINA E30 C2.7 HEADERS AND COLLECTOR
    THE WATER PUMP, TIMING BELT AND TENSIONER WILL BE NEW AND INSTALLED ON THE ENGINE
    ALSO INCLUDED IN THE PRICE IS A SPLIT SECOND MAF CONVERSION KIT W/INSTRUCTIONS
    524 TD CRANK
    I WILL POST PICTS OF ALL THAT IS INCLUDED IN THE UPCOMING DAYS
  • TwoJ's
    • Oct 2005
    • 4908
    how many moneys?
      • 37828
      Price please, it's part of the forum rules.
      Thanks.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • JAX S50
        • 107
        $4000 Obo And Can Deliver Up To 200 Miles Away From 92545 For A Small Gas Fee
        • JAX S50
          • 107
          More Info
          • JRKOUPE
            • Dec 2004
            • 3159
            engine
            Sounds nice..altho I've HEARD POLISHING IS A BIT OF A NO NO ON M20'S. Sorry for cap lock there. 4k might be a bit hi considering m50/s 50/52 are cheaper// or close enough and dead stock reliable.
            You realize some dyno pulls would help greatly for sale..are we talking 185 hp....or 200 hp or?
            .....and where is the power?......4500/5500/6500/7200?.....
            • mode
              • Jun 2007
              • 140
              Here is an offer. For a "built" m20, that has been in use for "a few years" and not knowing how much it has been abused......
              2k at the max. Are you trying to fund your s50, by selling an m20 at an unreasonable price/questionable history?
              Nothing says screaming like all caps. How did he get past the Anti-Caps feature on this forum?
              • Fidhle007
                I can fly, motherfucker
                • Oct 2005
                • 7209
                Want to get rid of the SS MAF seperately at all? If so, how much?
                '89 325is S50 Track Montser
                '04 X5 Daily/Tow Vehicle
                http://www.avarestoration.com
                http://www.myspace.com/brendanfiddle
                Click here if you want to be my zombie slave...
                http://www.youtube.com/user/Fidhle007
                • JGood
                  • Jan 2004
                  • 7959
                  Soooo, does this thing have a 150k hard miles on it, in which case since it's a built motor it's on it's last leg? A few years, is that 2 or 10?
                  It has a forged 2.7 crank, but euro 2.5 pistons? What rods work with that combo? Or are you just selling a 2.7 forged crank with it?
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • JAX S50
                    • 107
                    Okay here is the scoop on the engine I built it for my red 1990 325is which is also for sale here anyway I wanted to go with the M20 because it was easy to build up and would fit back in with no modification unlike the S50 little did I know how expensive the end project would come to I could have put the S50 in and had money left over, so now to answer some of your questions
                    The engine has never been abused as the car that it was in was a weekend driver at best I have about 6-7 cars at any given time so this car was not a daily driver more of a garage queen. The engine had right around 5000 miles on it when it was removed and that was over a 6 year period I can take some more photos of the valve train and bottom end it still looks new
                    As for trying to fund my s50 project that’s been done, right now I am in the process of parting out a 97 e36 M3 for spare back up parts to sit on the shelf and collect dust just so I have back-up’s available if something bad should happen. The real reason is the engine is taking up space in the garage and I would like to get it out of there but to let it go for 2k I think I will just put it in my e30 touring when it gets here so no thanks.
                    Sorry, new here and don’t know all the rules or etiquette for the forums
                    Want to get rid of the SS MAF separately at all? If so, how much?
                    No sorry want to sell whole package complete
                    No it has the original 2.5 crank and I rods, the 2.7 crank was not available at the time I built the engine (could not find one) so I put it together without it
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      m20..
                      Thanks for some insight.....but a BUILT m20 w/o objective numbers via dyno runs?......
                      and you dont have a big history on this forum to not be very detailed. Id offer 2100.....but not w/o more info.......much more. I can get an m50 for 1k.....or less.
                      What do ya say..........?...thank you.
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        Fid..
                        wazzup w/ the oil pans?.........pm me pls.
                        • PeaveyBassist
                          • Sep 2004
                          • 3511
                          For reference... I sold a stock rebuilt m20 w/o new rockers/springs for $800 picked up.
                          Will
                          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                          Welcome e30 (brilliantrot '90 325is) 12/23/06
                          DaveCN = Old Man
                          My signature picture was taken by ME! Not by anyone else!
                          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                          • JAX S50
                            • 107
                            What Do You Guys Think About This Then?
                            http://euromcars.com/90325is/
                            This is my red car that the engine was in and now I am trying to get $5000 for it, the engine is a low miles M20 w/80k on it that has been resealed and totaly gone through as far as hoses, belts and stuff and the car is very clean as you can see from the picts, Am i asking too much??
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              U R selling car w/ engine for 5k?.....
                              and /or engine alone for 4k?.......
                              Youre asking price for m20 is VERY hi..and your details and reasons for this price are very unclear/weak/and questionable....no offense intended.
                              How did u come up w/ 4k/>>>>? is it based on the money spent on it?.....because its not market value.
