Selling a couple things, everything is gently used and has very very little actual play/use time on it.
SOLD SOLD SOLD Nakamichi CD-500, mint. Comes with all original packaging and accessories as new. $325 ($695 new)
DLS CA41 4 channel amplifier. Comes with all original packaging and accessories as new. $250 ($495 new)
# Mode : AB
# Number of channels : 4
# Power output in 4 ohm (0,1% THD) : 4 x 70 W
# Power output in 2 ohm (0,2% THD) : 4 x 125 W
# Power output in 4 ohm bridge mode : 2 x 200 W
# Frequency range : 10 Hz - 35 kHz
# S / N-ratio, A-weighted : > 100 dB
# Damping factor : > 100
# Input impedance low level : > 10 kohm
# Input impedance, high level : 100 ohm
# Input sensitivity, variable : 0,25 - 5 V
# High level input with auto start : Yes
# Low level output : Yes
# Filter channel A & B : HP: 15-500 Hz. LP: 50-500 Hz / 0,5 - 5 kHz (x10)
# Filter channel C & D : HP: 15-500 Hz / 150 Hz - 5 kHz (x10)
# Grand bass adjustable frequency : 25 - 80 Hz
# Grand bass adjustable level : 0-18 dB
# Current draw, idle : 0,7 A
# Fuse value : 2 x 30 A
# Dimensions H x D x B : 67 x 354 x 250 mm (2,63 x 13,93 x 9,84 inch)
DLS CA12 mono amplifier. Comes with all original packaging and accessories as new. $200 ($395 new)
# Mode : AB
# Number of channels : 1
# Nominal RMS power output in 4 ohm (0,1% THD) : 220 W
# Nominal RMS power output in 2 ohm (0,4% THD) : 400 W
# Nominal RMS power output in 1 ohm (0,5% THD) : 500 W
# Highpass filter / subsonic variable : 15 - 150 Hz
# Lowpass filter variable : 50 - 500 Hz
# Continuously variable phase control : 0-180 degrees
# Dimensions H x D x B : 67 x 295 x 250 mm (2,63 x 11,6 x 9,84 inch)
# Mode : AB
# Mode : AB
