BUMP pm me to order
BMW E30 VER. 5 Carbon Fiber cold air intakes
Can you sell the hardware separately? I need another corrugated hose, and a rubber clamp would be nice.Rich!Comment
How much would one be without shipping?'87 325e 2.7i/5spd
'02 Subaru outback (Still smells like dirty hippie)
'86 635csi (Sold)
'87 4KcsQT (Sold)
'84 318i (Sold)Comment
For those that have any trouble installing here are some quick instructions.
I would suggest for anybody that plans on modifying an E30 to purchase a small metric bolt kit and maybe some hose clamps because I noticed on 325e AFM's my clamp can not tighten down enough unless you use an extra ring of rubber around the round port.
"Remove stock airbox and AFM together by loosening hose clamp and mounts.
Remove AFM from airbox
Install adapter onto AFM(new nuts may be needed)
install my filter with coupler onto the end of the AFM, before you put it into the car.
Remove headlight shield,grill and headlight(this is to gain access to put the front duct on easier)
It is possible to do with out removing but its pretty easy to pull those items off.
Move the cruise control unit off to the side and slightly bend the bracket that the air box was attached to, towards the driver side fender. This is to stop any damage to the carbon fiber finish that engine vibrations and movement may cause. Many customers don't do this but it makes life easy.
You now need to maneuver the Kamotors intake and AFM as one into the engine bay. the 3 ribs on the intake elbow boot to throttle will need to compress.
Now you need to slide the 3" duct onto the front of the unit, spinning the duct will help.
reinstall headlights and grill.
The straight bracket that was included can be used with the round bracket or by itself. the round bracket is not 100% needed, but the straight piece can be installed through the hose clamp and fastened to the body and will more than suffice.
after that your car should be good to go. Your ECU will take 10 minutes to adjust and then your car should pull strong and also have a nice growl."
7speedshop.comComment
Where does it connect too?? Since you say the old one air comes in behind the the light. So where does your kit get more air?. Just asking. ThanksComment
