JOM Coilover Group Buy
  • Stephen
    Шлем ишака
    • 10774
    #196
    has anyone compared front strut length to regular strut length yet?
    • ck_taft325is
      • Sep 2007
      • 6880
      #197
      Looked roughly the same length as the odd Billie sport I had kicking around in the garage. No actually measurement but a side by side. I'll try and find my camera and get some pictures.
      Need a part? PM me.
      • mightywhitey
        • Oct 2009
        • 985
        #198
        list updated.
        1991 e30 328i M52 swapped: Gone
        1995 e34 540i/6 1 of 76 Clean
        1985 e28 euro 525i the daily
        • einstein57
          • Jun 2007
          • 10780
          #199
          Out for delivery. Can't hardly wait
          www.gecoils.com
          • erik325i
            • Jan 2005
            • 3567
            #200
            Originally posted by mightywhitey
            If you have received your coil overs please let me know as well as I will be marking you as received on the list. Thanks, Mike
            I received mine yesterday.
            Originally posted by Stephen
            are the shocks even short enough to allow for sectioning? If it is, i may consider these but if they are regular length, you wont get very low
            Unfortunately, they are stock length.
            Also, the springs are pretty damn soft. They'll be fine for the beater I'm putting them in, but I wouldn't put them in any car you plan on driving aggressively.
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              #201
              So if you're going 2-3" lower on a stock-length shock with soft springs.... Are you riding on the bumpstops a lot?
              • erik325i
                • Jan 2005
                • 3567
                #202
                I haven't put them in yet, but compared to other coilover kits I've used, if you want to run it low with stock length struts, you will be on the bump stops.
                Here is my 325i (not the car getting these JOM coils). Before I shortened the strut housings, I was on the bump stops just sitting there, so I had no suspension travel.
                • DivineStyler
                  • Jan 2010
                  • 328
                  #203
                  can someone speak in lame mans terms... sorry I'm still learning... school me on bump stops? Does that mean the will basically be at the lowest position sitting on the part which prevents the car from dropping down any lower when it hits a bump?
                  If so the ride will be very stiff and hard yes? I don't know please explain... thanks.
                  AutoX w/ a Roof Rack for extra Aerodynamics...
                  • CHIF8008
                    • 3447
                    #204
                    so anyone put this on yet?? so if they are stock length, we cant cut sections out of the front?
                    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                    -The Beauty in the Tragedy-
                    MECHANIC SMASH!!- (you all know you do it)
                    Got Drop?? ;-)
                    But of course
                    E30s are know to be notoriously really really really ridiculously good looking
                    • mightywhitey
                      • Oct 2009
                      • 985
                      #205
                      List updated
                      • reelizmpro
                        • 9466
                        #206
                        Erik, did you measure the spring rates yourself or ?? how to did figure they were too soft?
                        Divine, if the kit uses stock length shocks, the springs better be stiff if you want to go LOW (2.5"+) if they aren't you will be bouncing off the bump stops of the shocks, perhaps eventually blowing them out. When you drop it LOW you are reducing the amount of shock travel right from the start. Soft springs = more shock travel. Hard springs = less shock travel. To go LOW and still have shock travel, GC uses a shorter shock insert, so you can cut the struts down an inch or so. You can't do this with stock length front shocks. This along with coilovers in front will allow you to dump the car while still having some suspension travel, at least enough to work properly.
                        88 M3 - LACHSSILBER/SCHWARZE
                        • erik325i
                          • Jan 2005
                          • 3567
                          #207
                          I don't have a spring rate tester, so I can't tell you the exact rates, but just by putting my weight (~175 lbs) on the spring, it compresses close to an inch and a half.
                          • Philo
                            Ich esse kleine Kinder
                            • 3334
                            #208
                            I'm going to hold off before I say the line.
                            -tim
                            Originally posted by Jordan
                            I like the stance
                            • CabbE30
                              • Aug 2009
                              • 2358
                              #209
                              ^^ Oo0oo The suspense! Its killing me!
                              • ck_taft325is
                                • Sep 2007
                                • 6880
                                #210
                                Which springs did you get, Erik? I contacted via E-mail for the heavier duty "cabrio" springs which according to them, are considerably stiffer.
                                Need a part? PM me.
