JOM Coilover Group Buy
  • reelizmpro
    • 9466
    #466
    Originally posted by E30AWDAZ
    Thanks keep in mind they still aren't settled yet. I would give these coilovers a 8 out of 10 because they are perfect for street setups! The shocks are a tad too soft for any other application though. It still rides alot smoother than my stock springs and blown shocks for sure. Now Im just waiting on my wheels to come in the mail
    That's plenty low for my tastes. I got the same drop with my GC setup without modified housings. Do you think the spring rates are as advertised? So you think the setup is underdamped? These are gas shocks right? Seems like a good kit for the price.
    88 M3 - LACHSSILBER/SCHWARZE
    • ak-
      • 12422
      #467
      Originally posted by mightywhitey
      For not cutting the strut tubes at all I am impressed with that for sure. Now I want to see some cut tube and GC rear spring dumpage. Good pics, thanks.
      You can't cut the tube with this setup. The shock insert is too long/stock like Bilstein Sports and such.
      Just pretend they are Bilstein sports and saying you want to cut the strut tube; same deal, you can't. You need a shorter shock insert to compensate for a shorter strut tube if cut.
      The people who have done this before are talking about cutting/grinding the bottom spring perch hat so you can fit your hand in there and adjust up and down.
      Like this:
      This strut tube hasn't been modified. It has just had the bottom spring perch ground/cut off
      See the bottom of the gold adjuster? That's where the perch used to be.
      Now you can fit your hand in to adjust with no problems.
      Hope that clears confusion!
      1991 325iS turbo
      • E30AWDAZ
        • 399
        #468
        8.9kg/mm is 498 lbs/in
        10.3kg/mm is 577 lbs/in
        ^^^ Does sound right for the spring rates. Keep in mind I have a convertible so its heavy and is probably making the ride a bit softer overall compared to if a 318is had this same kit. I'm not sure how to tell if they are gas shocks or not??
        • ak-
          • 12422
          #469
          Those are practically H&R Race rates with the front beefed up +150/lbs more.
          1991 325iS turbo
          • mightywhitey
            • Oct 2009
            • 985
            #470
            Like this:
            Definitely does!
            I think I was thinking of the way einstein did it. Looks like you gain 1'' of drop over leaving the strut top on.
            1991 e30 328i M52 swapped: Gone
            1995 e34 540i/6 1 of 76 Clean
            1985 e28 euro 525i the daily
            • einstein57
              • Jun 2007
              • 10780
              #471
              I don't know about the vert springs but the standard coupe and sedan springs are closer to sport then they are to race. I might be selling the springs only depending on how they perform after I finally button everything up.
              www.gecoils.com
              • AirplaneBuilder
                • 823
                #472
                Anyone measured the max drop you can get out of these from stock height? My current setup with H&R springs and bilstein sports got me 1.5 inches lower from stock but i want to go lower in the front, maybe another inch. Can this kit drop your car 2.5-3 inches from stock hieght? Thanks in advance!
                1989 Zinno 325i S50 ZF320
                • E30AWDAZ
                  • 399
                  #473
                  ^^^ After putting it on the lowest setting it will drop you 3 inches in the front and about like 2 to 2.5 in the back. Thats what it did with my vert. If I were you I would get them and use the billy sports with these coilovers
                  • AirplaneBuilder
                    • 823
                    #474
                    ^^^ Right now my front is really stiff cuz i also put the 15mm drop hats on so if i go another inch lower wouldnt it be too much for the billy sports to handle? Wouldnt a 3 inch drop and using billy sports be extremly stiff and too much for the billy sports?? I never ran coilovers on any of my cars so I'm totally new to them.
                    • reelizmpro
                      • 9466
                      #475
                      When I first got my vert, the PO dumped it on cut Eibachs and off the shelf Koni's. It looked good and had perfect stance but rode like shit and bottomed out very easily. Excessive drops means you have to run shorter shocks and very stiff spring rates or there won't be enough travel for the suspension to do it's job. If the springs aren't stiff enough, the shocks will ride on the bump stops and eventually blow. You need to run short body shocks like the GC Koni's but they are pricey. There's a reason GC revalved those short Koni's. With this kit (or any stock body length shocks), I wouldn't go lower than the picture posted in the first post.
                      • AirplaneBuilder
                        • 823
                        #476
                        ^^ Barry thanks for the info.
                        I guess ill just use the shocks this kit comes with and leave my other setup on the shelf incase i want to go back. My e30 is not a track car or a DD, more of a summer/ weekend car so im sure this kit will be fine for my needs.
                        • matias88e30
                          • Dec 2009
                          • 1110
                          #477
                          so nothing needs to be cutted welded right? looks really nice for the price.. when will the next group buy will be? thanks..
                          no more boosted m20, 91 318i...
                          • mightywhitey
                            • Oct 2009
                            • 985
                            #478
                            You can still order them at this price.
                            • matias88e30
                              • Dec 2009
                              • 1110
                              #479
                              NIce^^ thanks for repkying... i might be in in a months or so, i have to buy some other stuff for the turbo build..
                              • KenC
                                King of Kegstands
                                • 14396
                                #480
                                Unless you modify the internal bumpstop, the Bilsteins aren't going to be happy running that low.
                                Originally posted by Gruelius
