German Engineering Suspension GB
  • Fusion
    • Nov 2009
    • 3658
    #166
    Originally posted by einstein57
    I'll post up some install pics soon.
    Could you shortly sum up what has to be done?
    My main concern is I have a brand new suspension and would like to be able to keep as much of that as possible and not have to deal with shortening/welding the strut body.
    If your solution is easy to install without a professional shop doing it, I think I'm in.
    • xAZxE30x
      • 1238
      #167
      1. bloodshot-e30
      2. johnwoo-Coilovers, dust boots, and camber plates $455 (450f 650r)
      3. xoneslosentrax
      4. iwantspeed
      5. MR 325 (450f/650r w/camber plates)
      6. giantkeeper (w/ dust boots and camber plates 450f 650r - stiffer if available)
      7. noahp45
      8. mach schnell
      9. mtlbloodshot (450f 650r coilovers, dust boots, eurothane uppers and camber plates)
      10. Luis325 (race rates)
      11. Cronopoulos
      12. EThirty318i (450f 650r coilovers)
      13. jasonsnoddy (everything but keyless entry, 450f 650r)
      14. Puma (will be convinced by the goat)
      15. nebulous123 (Coilovers 450f 650r, dust boots, and camber plates)
      16. robert23 (450f 650r)
      17. der affe (500f 700r in a 6" spring)
      18. 6gen91 (stiffest setup )
      19. djjerme (450f 650r - possibly camber plates if the one's I got won't work..)
      20. e46s54dr (450f/650r + dust boot) edit: if stiffer rates are available, I'll take those.
      21. Brian D (300f 500r 6" springs + dust boots)
      22. Den_k321 ( 450f/650r )
      23. e30gentry no modification needed (450f 650r) dust boots and camber plates
      24. RagtopE30 (450f/650r or 500f/700r if available) camber plates, dust boots, rsm's
      25. IronmanE30 (pending discussion at the CarBeQue)
      26. howdyhoayman (don't know what spring rates yet but will get stiff af ones with camber plates)
      27. pputkowski - Coilovers (300f/500r), dust boots, and camber plates
      28. trackjunkie21- Coilovers (450f/650r)
      29. Robiniscool
      30. mhuynh- Coilovers (450f/650r)
      31. Kwill22- coilovers (450f/650r) camber plates dust boots
      32. Sonj91- coilovers (450f/650r)
      33. dave.a.cote - coilovers (450f/650r) camber plates dust boots
      34. spidmang - Coilovers (450f/650r)
      35. IRUNEDM - coilovers (450f/650r) camber plates dust boots
      36. xAZxE30x - Coilovers (500f/750r if i can get that) Camber plates, dust boots
      • spiDmang
        • 3941
        #168
        ill actually take a 350f/600r if there is enough interest!!
        91' 318iS - S54/6MT Swapped
        08' E90 M3 6MT - Daily
        Originally posted by IronJoe
        Originally posted by 2mAn
        • bloodshot-e30
          • 1494
          #169
          IIRC its like the cosmo setup just grind off the existing strut housing and put the coils on.
          ^Back in the game^
          BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
          FS thread:
          http://www.r3vlimited.com/board/showthread.php?t=214105
          • luis.e30325es
            • Feb 2011
            • 128
            #170
            1. bloodshot-e30
            3. xoneslosentrax
            4. iwantspeed
            7. noahp45
            8. mach schnell
            11. Cronopoulos
            29. Robiniscool
            37. Luis.e30325es- coilovers (450f/650r) and dust boots
            • mo diesil
              • Jan 2011
              • 275
              #171
              put me down for a set.
              • Fusion
                • Nov 2009
                • 3658
                #172
                1. bloodshot-e30
                3. xoneslosentrax
                4. iwantspeed
                7. noahp45
                8. mach schnell
                11. Cronopoulos
                29. Robiniscool
                38. Fusion - coilovers (450f/650r) and dust boots (international shipping, not in a hurry)
                • JGood
                  • Jan 2004
                  • 7959
                  #173
                  [quote=Fusion;2747839]1. bloodshot-e30
                  3. xoneslosentrax
                  4. iwantspeed
                  7. noahp45
                  8. mach schnell
                  11. Cronopoulos
                  29. Robiniscool
                  39. JGood - Coilovers (450f/650r) camber plates and dust boots
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • einstein57
                    • Jun 2007
                    • 10780
                    #174
                    1. bloodshot-e30
                    3. xoneslosentrax
                    4. iwantspeed
                    7. noahp45
                    8. mach schnell
                    11. Cronopoulos
                    29. Robiniscool
                    39. JGood - Coilovers (450f/650r) camber plates and dust boots[/QUOTE]
                    40. mo diesil
                    41. artfunk007
                    www.gecoils.com
                    • JGood
                      • Jan 2004
                      • 7959
                      #175
                      A few questions:
                      -For the fronts, you slide the sleeve right over the strut tube, and it sits down on the stock spring perch, the adjuster threads on, then you put the spring on, and then your choice of upper components?
                      -If I cut the spring perch off, I can weld the sleeve anywhere on the strut tube I want (to be lower, and for easier access)?
                      -I can keep my Bilstein Sports and gland nut that I'm current using on stock strut housings with H&R Race springs?
                      -If I get your camber plates, they will work with Bilstein Sports?
                      -If I don't get camber plates, the coilover kit comes with a top hat that works with the factory strut mount and Bilstein sports?
                      -For the rears, it's just a top hat and bottom sleeve with adjusters, and the spring?
                      • einstein57
                        • Jun 2007
                        • 10780
                        #176
                        When you cut the factory perch you cut just above the weld. The sleeves are an exact fit and the factory weld will hold the sleeve in place. The only benefit to completely griding off the factory welds and moving the sleeve lower would be if you have a stockpile of 7" and 8" spings.
                        The bilstein sports and gland nuts work great. Thats what i'm currently running. The aluminum spring hat that comes with the kit will work with the factory strut bearing or the camber plates. The konis may be different. I everyone that has installed these has had bilsteins.
                        For the rear i'm leaning toward a "pig tail" upper portion for the spring and a 2.5" sleeve with adjuster. This will allow you you use the factory upper spring pad with the very long spring aligment nipple. Makes it a ton easier to settle the spring after lifting up the car. IIRC TCkline does the same thing for their rear springs.
                        www.gecoils.com
                        • noahp45
                          • Jun 2011
                          • 107
                          #177
                          1. bloodshot-e30
                          3. xoneslosentrax
                          4. iwantspeed
                          7. noahp45 (Coilovers (dk spring rates yet) with Camber plates
                          8. mach schnell
                          11. Cronopoulos
                          29. Robiniscool
                          30. mhuyn h- Coilovers (450f/650r)
                          39. JGood - Coilovers (450f/650r) camber plates and dust boots[/quote]
                          40. mo diesil
                          41. artfunk007
                          • Fusion
                            • Nov 2009
                            • 3658
                            #178
                            I think Koni's have a thicker top threaded part of the shaft where the camber plate sits.
                            My camber plates had spacers and I had to have them milled for the Koni's.
                            I'll be using the D2 plates, I think they should work without the adapter I had machined.
                              • 37825
                              #179
                              Nigel, that would be really cool on the rears!
                              Classic BMW Specialists
                              Santa Clarita, CA
                              www.BimmerHeads.com
                              • mtlbloodshot
                                • Jul 2011
                                • 761
                                #180
                                Any pics?
                                MY BUILD THREAD
                                http://www.r3vlimited.com/board/showthread.php?t=235231
                                INSTAGRAM : @luchcolaneri
