German Engineering Suspension GB
  • Fusion
    • Nov 2009
    • 3658
    #196
    In my suspension build, I used stock upper spring plates so I had to make the camber plates higher in order to replicate the height of the stock upper mounts.
    The red part is the adapter. I had to design a 20mm spacer to "lift" the camber plate to the correct position. So in my opionion, if you were to use stock upper mounts, you should be about 2cm higher than someone with camber plates (with the coilovers set at the same height). In other words, you will lose about 2cm of the maximum lowering that would theoretically be possible.
    Plus my camber plates have an extra plate for caster, that's another 7mm, IIRC. Either way, the camber plates should be about 1/3 the stack height of a stock upper mount, so just that will lower your car about 1.5in, the rest depends on spring length etc.
    • noahp45
      • Jun 2011
      • 107
      #197
      I'am feeling these better then the JOM stuff
      • einstein57
        • Jun 2007
        • 10780
        #198
        Joms are pretty nice. They remind me alot of the FK kit on my VW. The only thing that really got to me was the fact the rear does not go as low as the front. I think they should also have made the sleeves longer in the front to give people the option of swapping springs. The the fit was spot on and install is a breeze. These observations are what inspired me to make my own kits.
        www.gecoils.com
        • ADCD875
          • Dec 2008
          • 115
          #199
          One More
          1. bloodshot-e30
          2. johnwoo-Coilovers, dust boots, and camber plates $455 (450f 650r)
          3. xoneslosentrax
          4. iwantspeed
          5. MR 325 (450f/650r w/camber plates)
          6. giantkeeper (w/ dust boots and camber plates 450f 650r - stiffer if available)
          7. noahp45 (Coilovers (dk spring rates yet) with Camber plates
          8. mach schnell
          9. mtlbloodshot (450f 650r coilovers, dust boots, eurothane uppers and camber plates)
          10. Luis325 (race rates)
          11. Cronopoulos
          12. EThirty318i (450f 650r coilovers)
          13. jasonsnoddy (everything but keyless entry, 450f 650r)
          14. Puma (will be convinced by the goat)
          15. nebulous123 (Coilovers 450f 650r, dust boots, and camber plates)
          16. robert23 (450f 650r)
          17. der affe (500f 700r in a 6" spring)
          18. 6gen91 (stiffest setup )
          19. djjerme (450f 650r - possibly camber plates if the one's I got won't work..)
          20. e46s54dr (450f/650r + dust boot) edit: if stiffer rates are available, I'll take those.
          21. Brian D (300f 500r 6" springs + dust boots)
          22. Den_k321 ( 450f/650r )
          23. e30gentry no modification needed (450f 650r) dust boots and camber plates
          24. RagtopE30 (450f/650r or 500f/700r if available) camber plates, dust boots, rsm's
          25. IronmanE30 (pending discussion at the CarBeQue)
          26. howdyhoayman (don't know what spring rates yet but will get stiff af ones with camber plates)
          27. pputkowski - Coilovers (300f/500r), dust boots, and camber plates
          28. trackjunkie21- Coilovers (450f/650r)
          29. Robiniscool
          30. mhuyn h- Coilovers (450f/650r)
          31. Kwill22- coilovers (450f/650r) camber plates dust boots
          32. Sonj91- coilovers (450f/650r)
          33. dave.a.cote - coilovers (450f/650r) camber plates dust boots
          34. spidmang - Coilovers (450f/650r)
          35. IRUNEDM - coilovers (450f/650r) camber plates dust boots
          36. xAZxE30x - Coilovers (500f/750r if i can get that) Camber plates, dust boots
          37. Luis.e30325es- coilovers (450f/650r) and dust boots
          38. Fusion - coilovers (450f/650r) and dust boots (international shipping, not in a hurry)
          39. JGood - Coilovers (450f/650r) camber plates and dust boots[/quote]
          40. mo diesil
          41. artfunk007
          42. ADCD875 - coilovers (450f/650r) and Dust Boots
          • ADCD875
            • Dec 2008
            • 115
            #200
            Thanks for making these available. I added myself to the list for 450F/650R. One question: I have 1991 318is with Bilstein Sport shocks and Eibach ProKit springs. I like the stance of the car (not slammed) but I hate how soft it is. Hope these will stiffen the ride a lot while maintaining the same ride height with the Eibachs that I have now?
            Thanks
            • e46s54dr
              • May 2008
              • 1059
              #201
              Thanks
              They're coilovers so the ride height you're looking for is definitely in its range.
              • Cronopoulos
                • Jul 2011
                • 2187
                #202
                Updated myself in the list with more information -
                1. bloodshot-e30
                3. xoneslosentrax
                4. iwantspeed
                8. mach schnell
                11. Cronopoulos (450f/650r or 500f/700r if available) camber plates, dust boots, rsm's...
                29. Robiniscool
                40. mo diesil
                41. artfunk007
                Project log -- DIRTY 30
                2.7i * Megasquirt tuned * E85 powered
                • einstein57
                  • Jun 2007
                  • 10780
                  #203
                  O these will be a ton stiffer then the prokits and be able to get lower if desired.
                  Eibach Pro-Kit 102F/277R 450f/650r will be a huge difference.
                  www.gecoils.com
                  • e46s54dr
                    • May 2008
                    • 1059
                    #204
                    Also updated the list with my name first....
                    0. e46s54dr- (450:nice:f/650r):nice:
                    1. bloodshot-e30
                    3. xoneslosentrax
                    4. iwantspeed
                    8. mach schnell
                    29. Robiniscool
                    40. mo diesil
                    41. artfunk007
                    • einstein57
                      • Jun 2007
                      • 10780
                      #205
                      Ok guys. Start PMing me your email address' so i can send out invoices.
                      www.gecoils.com
                      • noahp45
                        • Jun 2011
                        • 107
                        #206
                        when do you want the payment?
                        • marco 325 a
                          • May 2011
                          • 83
                          #207
                          Ok nigel sign me up for 450f & 650r I will pm with email thanks
                          • noE30
                            • Jun 2008
                            • 2260
                            #208
                            1. bloodshot-e30
                            3. xoneslosentrax
                            4. iwantspeed
                            8. mach schnell
                            29. Robiniscool
                            40. mo diesil
                            41. artfunk007
                            43. noe30 - Coilovers (45/650) and dust boots
                            Flickr
                            @michael.colby on Instagram
                            "All he needed was a wheel in his hand and four on the road"
                            • Harry's E30
                              • 643
                              #209
                              0. e46s54dr- (450f/650r)
                              1. bloodshot-e30
                              3. xoneslosentrax
                              4. iwantspeed
                              8. mach schnell
                              29. Robiniscool
                              40. mo diesil
                              41. artfunk007
                              44. Harry's e30 (450f/650r) possibly dust boots and camber plates
                              BUILD-http://www.r3vlimited.com/board/showthread.php?t=242728
                              • dinanm3atl
                                • Feb 2007
                                • 7305
                                #210
                                This is pretty darn cool. Have something similar coming soon that I purchased. I would have done this here otherwise. I like the spring lengths and then just removing the OEM spring perch(with 6" spring). Very nice!
