German Engineering Suspension GB
  • JGood
    • Jan 2004
    • 7959
    #856
    I'm just going to take about 3" out of the strut housing and run 325ix inserts, so I'll use the springs you sent me, but still would like to exchange the shiny front parts.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • RagtopE30
      • Dec 2010
      • 1869
      #857
      Please send mine "as is"
      Thank you
      450whp 524 lb-ft 1988 336ic In progress
      http://www.r3vlimited.com/board/showthread.php?t=250709
      • einstein57
        • Jun 2007
        • 10780
        #858
        Originally posted by mammoth_e30
        I have camber plates so i am good with the current set up
        I'll drop them off tonight so you can test fit.
        Thank you
        Will heading out to the post office.
        K.
        www.gecoils.com
        • m3guru
          • Jul 2011
          • 17
          #859
          I'll take as is, I'll be using camber plates eventually.
          Pierre
          m3guru.bmwe30m3.net
          • rares
            • 730
            #860
            do you have any sets for non group-buy customers? let me know, i think i may just go with the red colored ones... no dust boots...
            also, do these fit both 45mm and 51mm strut housings?
            Thanks einstein
            • einstein57
              • Jun 2007
              • 10780
              #861
              If you want them as is i can sell them. The current length is perfect for someone who is planning on shortening their strut tubes to run ix, mr2, or koni race inserts. Otherwise you'd want to grind off the factory perch and weld on a new one 1-2" lower to be stanced.
              www.gecoils.com
              • rares
                • 730
                #862
                so without any of these modifications, it wont really go low?
                • PNWDan
                  • Feb 2011
                  • 1326
                  #863
                  What would be the down side of the shorter spring options?
                  1987 Alpinweiß 325is
                  Like the PNW E30 Local Crew Facebook page
                  • einstein57
                    • Jun 2007
                    • 10780
                    #864
                    Not as linear accross the compression range. That is more important on a race car then a street car as the difference is minimal. With out any modifications or chaning the springs your looking at about an inch of fender gap.
                    www.gecoils.com
                    • rares
                      • 730
                      #865
                      if you cut the housing, will there still be enough threads on the inside to hold the shock in safely?
                      • Robert
                        • Dec 2010
                        • 3770
                        #866
                        you section it.
                        You don't straight cut it from the top, cut from somewhere in the middle , and reweld it.
                        • mkcman17
                          • Jul 2010
                          • 8240
                          #867
                          he's talking about sectioning, not just just cutting off the top of the housing.
                          1989 LN106 Hilux / 3.0TD SFA
                          1974 2002tii / stock
                          2002 IS300 / 5spd LSD
                          • einstein57
                            • Jun 2007
                            • 10780
                            #868
                            You don't want to cut the housings at all unless your going to run shorter strut inserts. There are some nice write ups in the suspension thread. Perhaps I'll do a full write up showing what tools I used and such.
                            www.gecoils.com
                            • rares
                              • 730
                              #869
                              Oh, cool, so if you are running stock length shocks, you just slide the sleeve over the housing?
                              • einstein57
                                • Jun 2007
                                • 10780
                                #870
                                That is correct. Here is a pic of garagistics install on the earlier kit. I believe reelizmpro has his installed the same way.
                                Lots of good information can be found in the DIY section
                                www.gecoils.com
