FEELER- anyone want a 6 speed?
  • nsxguy7
    • Sep 2013
    • 36
    I have a breaker in the UK I have done a good deal of business with lately. I started thinking about a 6 speed transmission for my project lately. As it turns out, ZF six speeds are quite common in Europe and share the same pattern as the Getrag 265. Most of them come out of the Europe-only 320d built from 2003-2006. If five of us want one, the price would be $750 each shipped to me in Denver. I work for a trucking company so I could ship to the rest of the US for another 50 bucks. Bear in mind that people drive a lot less across the pond and none of the transmissions he sees have done 70k miles. PM me if interested and thanks.
  • viceversa
    • 83
    o wow very tempting....lemme think about it lol
    1993 BMW 325iC -S52
    • LJ851
      • 7919
      So this is just for the M30 and most the the 4cyl powered cars only?
      Lorin
      The M30 is God's engine.
      • RondoAcapriccio
        • Jul 2011
        • 524
        82 528e and 85 535 came with g265, not sure if the location of the bell housing bolts are different, but just FYI. Awaiting more info from OP.
        • LJ851
          • 7919
          265 has a removable bellhousing. The '82 528e was the only 265 that that ever had a m20 bolt pattern, a 1 year only bell housing.
          A 265 bolt pattern is M30/M10 and similar 99.99% of the time. If OP was suggesting the 6 speed fit M20 bolt patterns, a better choice of gearbox to compare to would be suggested.
          Lorin
          • jaywood
            • Jul 2010
            • 4528
            6 speed m20...I'd be down :)
            • brian52555
              • 425
              Running this setup on my M20 e30. Highly recommended.
              • Cornell77
                • Oct 2009
                • 48
                Is it a direct bolt-in with no other changes needed?
                • Swanny
                  • Mar 2012
                  • 2834
                  Whats the gearing on these guys? I bet a lot of the swap guys would love a tall 6th for highway cruising. Also, no difference in the spacing for the clutch, 100% bolt on?
                  Edit - whooops...bolt on question asked already.
                  Swanny!
                  SUCKERS.
                  • 325_e30
                    • Jan 2008
                    • 2492
                    I would be interested pending the bolt on question answer.
                    LSx e36TI coming soon
                    Originally posted by s0urce
                    Man, she'd be so easy to rape
                    • dustyperez
                      • Feb 2012
                      • 390
                      This is what the wiki says,
                      The ZF S6-37 is a 6-speed manual transmission manufactured by ZF Friedrichshafen AG. It is designed for longitudinal engine applications, and is rated to handle up to 370 newton metres (273 lbf·ft) of torque.
                      Gear ratios:
                      1 2 3 4 5 6 R
                      4.350 2.496 1.665 1.234 1.000 0.851 3.926------zf
                      3.83:1 2.20:1 1.40:1 1.00:1 0.81:1 3.71:1-----g260
                      So it doesn't give you a longer highway gear, just an extra, shorter gear
                      • M-technik-3
                        • 18946
                        Thinking since they were for late model they would most likely fit 24V engine pattern.
                        • MaxBell
                          • 1391
                          So the 6th gear is just like the 5th gear in the G260?
                          REMEMBER: Be safe and have fun is Rule Number 1.
                          The Epic Unbuild of Clint Eastwood
                          • mkcman17
                            • Jul 2010
                            • 8240
                            Doing this swap right now....it would be sweet to have one in both e30s...
                            How certain are you on 800 usd shipped?
                            1989 LN106 Hilux / 3.0TD SFA
                            1974 2002tii / stock
                            2002 IS300 / 5spd LSD
                            • JGood
                              • Jan 2004
                              • 7959
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
