Carbon Airbox and Alpha N GB 2016 - S14-S50-S54-S65
  • maxx-automotive
    • Apr 2006
    • 87
    2016 group buy for carbon intake systems (aka CF airbox), currently in progress.
    These CF airboxes are hand made here in Germany. Applications range from "fast road" to race. The airboxes have been deployed on many different cars and run at tracks around the world, including the famous Nuerburgring Nordschleife.
    Airboxes are being manufactured now and shipping as they complete (in batches). So if your order is in early, you will receive your airbox earlier. Typical lead time from order to dispatch is approx. 2-3 weeks. We have not yet set a closing date (most likely approx. Dec. 15)
    If you are interested in participating and wish to have your name on the list, please send an email with your details (name, shipping address, part, etc.) to: info@s14power.com
    There are various carbon fiber airbox systems and air plenum intakes available. The airbox systems include snorkels and install kits where required. Some of the versions available:
    • E30 M3 S14 DTM CF airbox for 46, 48, 49 or 50 mm throttle bodies
    • E30 M3 S14 DTM CF airbox for S38 50 mm throttle body conversion
    • E30 M3 S14 DTM 8-injector CF airbox ('92 type with bottom mount injectors)
    • E30 M3 S14 CF replica plenum (weighs just 1.5 lbs)
    • 2002 M2 S14 CF airbox
    • E92 M3 S65 (for stock engine management)
    • E60 M5 S85 (for stock engine management)
    • E46 M3 S54 CF airbox (for Alpha N type engine management, 120 mm or 200 mm snorkel inlet)
    • E46 M3 S54 CF airbox (race version with central kidney intake)
    • E46 M3 S54 MAF CF airbox (for stock engine management, 120 mm snorkel inlet)
    • E30 M3 S54 CF airbox (for Alpha N or stock type engine management)
    • E36 M3 S50 CF airbox (for Alpha N type engine management)
    • E36 M3 S50 MAF CF airbox (for stock engine management)
    • E34 M5 S38 CF airbox (for Alpha N type engine management)
    Current group buy price list in euro (ca. 20% off). Prices are for complete kits so everything is included:
    CF Replica Plenum S14 : 650
    CF Airbox S14 46/18 with CF snorkel and install kit : 1175
    CF Airbox S14 48/18 with CF snorkel and install kit : 1175
    CF Airbox S14 49/18 with CF snorkel and install kit : 1215
    CF Airbox S14 50/18 with CF snorkel and install kit : 1215
    CF Airbox S14 50/18 (S38 TB) with CF snorkel and install kit: 1295
    CF Airbox S14 8-injector version with CF snorkel and install kit:
    CF Airbox S14 2002tii 46-50/18 with install kit : 1065
    CF Air Filter Housing for S14 (optional) : 150
    CF Airbox installation kit only : 150
    CF Airbox S50 : 1295
    CF Airbox S50 MAF : 1360
    CF Airbox S54 / 200 mm CF snorkel (internal filter) : 1595
    CF Airbox S54 / 120 mm CF snorkel (internal filter) : 1595
    CSL airfilter : 135
    CF Airbox S54 / 120 mm CF snorkel (external filter) : 1595
    CF Airbox S54 MAF / 120 mm CF snorkel : 1680
    CF Airbox S54 race with CF central intake snorkel : 1950
    CF Airbox S54 version II race with CF central intake snorkel :
    CF Airbox S65 (E92) : 1795
    CF Airbox S85 (E60) : 2250
    Maxx Alpha N V2.0 with WBO2 closed loop: 720
    TE WBO2 kit with WBO sensor LX1 remote display: 370
    Chip for S14 motronic: inquire (engine configuration dependent)
    Note: Schrick cams and other Schrick valve train parts available.
    Inquire for package deals which include Schrick parts and Maxx Alpha N.
    ECU software is available for S14, S50, S54, S65 and S85 using factory ECU. Options for engine installations into different chassis: EWS delete, speed signal delete, DSC delete, Cat monitoring delete, Alpha N mode, VMAX disable, etc. Drive-by-wire (electronically controlled TBs) can be retained when installing engines in different chassis.
    For S14 (E30 M3 and 2002tii) specific applications:
    Maxx Alpha N V2.0 with Wideband O2 closed loop control & lambda target map: 720 euro
    S14 DTM CF Airbox System -- large volume plenum, long runners, 46 or 48 mm diameter (49 & 50 mm also available, see above):
    • CF airbox with install kit: 960 euro
    • CF snorkel kit: 155 euro
    • Brake reservoir relocation kit: 60 euro (not required on race cars with dual master cylinders)
    Total CF Airbox kit: 1175 euro (Total minus install kit: 1060 euro)
    optional:
    CF air filter housing for inside front bumper (for use on non-AC cars or with custom AC radiator): 150 euro
    2002 S14 airbox (requires 2002tii brake booster):
    • CF airbox with install kit: 1045 euro
    • extra large air-hose: 20 euro
    NOTE: brake reservoir relocation kit and snorkel are not required on the 2002 setup.
    CF replica plenum for stock (AFM) installations: 650 euro
    Pictures of CF Airboxes / installations:
    S14 airbox:
    2002/S14 airbox installation:
    S14 CF replica plenum (for use with AFM / MAF / or Alpha N):
    E46/S54 airbox for use with MAF/HFM or Alpha N (also versions using alternate snorkels and internal or external air filters):
    E46/S54 airbox with central air intake from the "kidneys":
    E30/S54 airbox installation (for use with MAF/HFM or Alpha N):
    E92/S65 CF plenum installation:
    E36/S50 airbox for use with MAF/HFM or Alpha N:
    E34/S38 airbox installation:
    Alpha N kit:
    Maxx Alpha N Wideband O2 closed loop control:
    Pictures can also be found here: http://s14power.com/airboxes.html
    sales@maxx-automotive.com
  • maxx-automotive
    • Apr 2006
    • 87
    Additional pics...
    E30 versions of the S50 and S54 airboxes have shorter intake snorkels for E30 application. Both airbox variants also work in E36 and E28 chassis. The new S50 version allows to use an internal air filter just like the S54 version does. With the air filter being internal this allows easier/simpler airbox installation and the airbox is larger in volume as well.
    S54 Z3 M coupe installation:
    S54 E36 installation:
    New S50 airbox with internal air filter (similar to s54 airbox) in e30:
    longer necked down snorkel (200 mm --> 120 mm)
    shorter 200 mm snorkel with modified angle
    Traditional type S50 in e30:
    S54 in e30:
    Some S14 installs:
    S14 airbox for S38 50 mm TBs:
    • garagewelt
      • May 2008
      • 847
      If I have an older model Alpha N Serial 000121 ID V1.03, who can upgrade it and how much will it cost?
      Interested in the S14 Box.
      Thanks!
      90 Alpine M3 | 90 Brilliantrot M3 | 85 Alpine 520i
      • maxx-automotive
        • Apr 2006
        • 87
        you will have to send it in since you will get new hardware and software installed. send me an email.
        • maxx-automotive
          • Apr 2006
          • 87
          BTW, we can reprogram the factory MSS54 + MSS54HP ECU (for s54 airbox installs). The MSS54 can be upgraded to MSS54HP with larger memory chips.
          -- EWS delete
          -- speed signal delete
          -- DSC delete
          -- Cat monitoring delete
          -- secondary air-injection delete
          -- Alpha N mode
          -- VMAX disable
          -- sport mode can be permanently enabled
          -- adapter harness available for connecting to E36 chassis (plug n play).
          (you can keep drive-by-wire electronic gas pedal)
          • 2mAn
            Señior Mod
            • 20972
            Im guessing that the S50 is the Euro S50, not the US S50
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • maxx-automotive
              • Apr 2006
              • 87
              With M Power sticker under clear coat:
              dyno plot (S14B25, CF airbox, Alpha N):
              • mscott
                • Sep 2006
                • 182
                Cf s14
                Email sent
                • burkey001
                  • Feb 2011
                  • 608
                  pictures of the internals of the E30 M3 S54 CF airbox (for Alpha N or stock type engine management)
                  88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                  90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                  • Staszek
                    • 2533
                    Wow this looks awesome, and I am definitely interested. I have a few questions about intake and the brake booster on the S54 in an E30. In the pics you show it looks like you angled the build on the intake to fit the booster better. What booster is that in the pic?
                    • maxx-automotive
                      • Apr 2006
                      • 87
                      There are different boosters being used. That one went to the UK and I believe he used a booster from a ford van. Others have also used one from a renault clio which is smaller. The airbox had an indentation to help clear the larger booster.
                      • 2mAn
                        Señior Mod
                        • 20972
                        :hitler:
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • maxx-automotive
                          • Apr 2006
                          • 87
                          Yes, S50 refers to the euro motor. You need to have ITBs. Its been done before also on an M50 engine (with ITB).
                          • 2mAn
                            Señior Mod
                            • 20972
                            thats what I figured. dreams crushed.
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • maxx-automotive
                              • Apr 2006
                              • 87
                              This one is available now (can ship immediately).
                              Brand new, never installed, for S14 engine (e30 m3, 320is, but not 2002 M2. 2002 M2 uses a different version)
                              Airbox has the BMW M Power sticker under clear coat.
                              S14 CF airbox 48/18 + CF snorkel + installation kit (not shown in foto): $1328 (1175 eur) + shipping from Germany
                              pics:
