wack
lol
lol
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Tags: None -
I've heard good things about these mounts too. I may redo my entire suspension one weekend with his bushings, I just need to see when i'll have the time. How many people's opinions agreed with yours of "not harsh"? That's very subjective and extremely hard to define. I consider my car a comfortable DD, but I think that solid engine and tranny mounts would push it over the edge to being fairly uncomfortable.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP) -
Been Running these on the street about 4k miles and love them.
Such a nice setup..
Can't say enough about the condor solid mounts. Perfect fit, awesome feel.
Customer for Life...
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
I have engine and transmission mounts on mine, everything else is AKG 80A. Wished I knew of Condor before I bought my stuff two years ago.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8isComment
So does he have this kit for sale now?
Build Thread
http://www.e30tech.com/forum/showthread.php?t=84988
"When In Doubt Boost It Out"
~89 325I Turbo 11.90 @ 121~
~ 420whp/420tq~
15psi
~Paul Burke Built 2.8L Stroked M20
~666 Divided Mani T3
~6262 T3 Turbo
~O'ringed Block SS
~Custom Fuel System
~3'' Turbo Back
~50mm Tial Bov
~Dual Tial 38 GatesComment
•• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
•• Rear Subframe Bushings • RTABs • Facebook ••
im thinking of buy the motor ones im thinking wound the car vibrate a bit
http://www.condorspeedshop.com/colle...mount-set-uhmw
12mm Rear Subframe Riser Bushing Sets are Available
(click on photos for payment info)
12mm Rear Subframe Riser Bushing Sets are here! These solid bushings raise the subframe a full 12mm to correct extreme negative camber on lowered cars. We provide you with differential spacers and longer differential bolts to complete the installation. Pair them with a Differential Mount - UHMW (comparable to Delrin. You will see a 4.0 - 4.5 degrees reduction in camber. Most slammed e30s are at -6 degrees of camber, with this kit, you will be at a tire friendly -1.5 degrees.
The subframe and differential mounting point is the heart of the rear suspension in an E30. When they move, so do all of the rear suspension mounting points. Replacing the stock rubber subframe and differential bushings with UHMW will limit drivetrain and suspension movement and keep your car’s suspension geometry the way it’s supposed to be. They will last longer than the original rubber and do not 'wind up' under load/unload, transferring more power through the axles to the wheels.
"You can compare to Solid Aluminum mounts in stiffness, but to Poly mounts in vibration"
The Condor E30 solid subframe and differential mount bushing kit is a direct replacement for the stock BMW subframe mounts and differential bushing. For BMW e30 (318 323 325 M3, not iX)
Fastest way to correct neg camber! I went the weld in camber correction kit...but still have camber. I think this kit would be a perfect combo to the weld in kit for extremely low track minded e30s. Make use of that full tire contact!
I will be coming back here for my next set of bushings! Do you know if you will be offering them in alum with the 12mm of correction?~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Current cars:
~ '87 535
What's the benefit of an aluminum mount over UHMW?The first car I ever rode in was an e30
2003 GSX-R 750 (RIP)Comment
