Classified Forums - Read this first!
Here are a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed.
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the item's information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item may be worth.
If listing a car, post:
-The year and model
-An accurate mileage. If the odometer is broken, post what it reads currently and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-A price
-As many pictures as possible of every area
If listing wheels and/or tires, post:
-The brand and model
-As many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. For tires, note any gashes, bubbles, cupping or curb rash
-A price
-As many pictures as possible of every wheel
If listing parts, post:
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-A price
For miscellaneous items, post:
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-A price
For WTB threads
-Be as detailed as possible.
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post a price range of what you are willing to pay (typically based on condition).
-Post where you are located and if you would prefer local pickup.
In case the point was not made, everything being sold on this forum must include a price and as many pictures as possible.
-This is not eBay or Craigslist (or any other buy/sell/trade site). Do not post links to those for your ad. The same goes for linking to ads on other forums... either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-Cross-posting within the R3VLimited forum is not allowed. Choose a single subforum for your ad.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top.
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, stay out of the thread or be prepared for a time out. If you complain about the time out, it will be extended.
-Threads can be bumped a maximum of once per day (24h). You are allowed to respond to others more than once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Shadowline Motorsport E30 LED Headlight Upgrade
    I had been searching for a good while on a decent upgrade that would enhance my night time driving. I have been spoiled with HIDs that came standard with my E46 and my E70, so I stumbled across some LED low beam lights from Shadowline Motorsport that would be essentially a plug and play setup for my 9006 bulbs. Because my car came with ellipsoids from the factory, it was a pretty seamless install. The kit I used was the R6 6000k that has 4 LEDs separated by 90 degrees.
    Quality
    These arrived in a box that seemed pretty nice. Almost felt like I had purchased an Apple product with the color and "feel" of the box.
    What's interesting about these is that there is no fan on them. Apparently the heat is dissipated through the braids that are on the end of the bulbs. Other ones I have seen on the market have said fan. I will have to see how these hold up over the stresses of heat and time, which will be updated later on.
    Installation
    Installation was honestly quite simple. You take out the old bulb and put the new one in. The kit came with an assortment of o-rings and a couple gaskets, but the only thing that I needed was 2 of the larger o-rings to give the bulbs a nice and firm seating. The one thing that I had to take careful note of is that when you are installing them, make sure you have the fins in the correct position. If you don't, the bulb will somehow stay stuck and loose in the housing.
    Passenger side:
    Driver side:
    As you can see, the driver's side is a tight fit but it can be done. I was pretty careful to not scrape anything despite how robust LED's are compared to HID's.
    Lighting
    The lighting is where I am somewhat questioning this but one would also have to remember that when the ellipsoids were brand new, they were optimized for 9006 bulbs:
    9006 on the left, LED on the right (As you can see, the lighting seems more clear compared to the stock 9006 bulbs):
    Now when compared side by side to a factory BMW HID kit, the results are honestly quite impressive for something that was never really engineered for HID/LED setups.
    My E46 with factory HIDs and the E30 with the LEDs:
    As you can see, the light isn't really spread as well as the HIDs. For a relatively inexpensive aftermarket upgrade, it's not too bad.
    Another shot with both installed:
    I took it for a drive after it got dark, and although I wasn't able to get any night time shots, I can say that the lighting has certainly improved. The instant on and having a more white light is worth it to me. I will update with some night time driving when I get more free time.
    Final Verdict
    Is it worth it? Yes. As technology progresses and becomes widely available, there really isn't much of an excuse for someone to skip out on something that comes standard on a lot of modern vehicles. Like I stated before, this is a relatively inexpensive upgrade.
    If you're interested in them, visit Shadowline Motorsport's Home Page and check out the different options they have.
    1989 325i - 2.7i, Holset H1C, 42lb injectors, 14.7 psi, whodwho MS-PNP.
    2009 X5 - DD Duty
    2018 VW Atlas - Wife/kiddie/grocery hauler
    The Group Buy is currently open, here's the Official Thread.
    Jeff,
    Thanks for taking the time to provide such a detailed review, its much appreciated.
    Best Regards,
    Bryon
    Wheelwell
    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
    LED Bulb Thread
    R6 LED Review
      Thanks for the review! I'm still on the fence about LED's vs HID's, but the price for LED's is just so tempting.
      My Garage
      Feedback
      Instagram: Stone.Hopkins
        Do they throw a low beam check light? I am running some other LEDs right now and get the LBF in the rain or when I turn the lights off.
          Looks radically inferior to HIDs, as with every other plug in LED upgrade that I've seen.
          LED high beams pair really well with a bi-xenon retrofit, though. They are spectacular for flashing people. I run a bi-xenon + drop in LED setup in my E36 and it's fantastic.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
            Bronzit....it's growing on me slowly. Thanks for review, I have 9 year old DDM Tuning HID's in my car still amazing they still work well.
              no, there is no check that comes on.
              2009 X5 - DD Duty
                Cool.
                2009 X5 - DD Duty
                  LEDs are a great upgrade for the high beams. I haven't seen them do too well with projectors. Maybe the smaller reflectors that projectors have need a light bulb that shines light 360 degrees?
                  AWD > RWD
                    The bulbs tested by the op are the R6 which distribute the light 360 degrees. However performance will vary based on the projector design.
                    Sent from my iPhone using Tapatalk Pro
                    Wheelwell
                    LED Bulb Thread
                    R6 LED Review
                      So you've had these for almost a year now, do you have an update on these?
                      1990 325is
                      m52b28
                      3.73lsd
                      g260 (1987 325is 5spd tranny)
                        Yes! They still work great to this day and have yet to experience any issues.
                        2009 X5 - DD Duty
                          Awesome!
                          1990 325is
                          m52b28
                          3.73lsd
