After some research, it seems the electrical connection for the in tank pump is hanging on by a thread. Is this common? Requires new pump, I guess? The connection to the fuel level sending unit is intact and can be removed. The other connection I speak of popped off as soon as I touched it. It rusted off the car. Where does this connection go to?
Spectra Premium Gas tank
The early and late cars take 2 different types of connectors.
Late is a sealed connector terminal that matches thinks like coolant reservoir level sensor in a late car.
Early connector terminals match the same as your front turn signals.
Both can be bought new from BMW, I can get the P/n if that helps.
Originally posted by moatilliatta View PostThe early and late cars take 2 different types of connectors. Late is a sealed connector terminal that matches thinks like coolant reservoir level sensor in a late car. Early connector terminals match the same as your front turn signals. Both can be bought new from BMW, I can get the P/n if that helps.
