very nice!
					42 Draft Designs Spacers and Adapters
Ethan, which variant would I need to put on my Apex ARC-8s? They're 17x8 (ET25, 57.1 E30 centerbore), I just want to put a 10mm in the rear, nothing up front.
Would the non hub-centric 10mm leave enough of the centerbore on the actual hub to fit into the centerbore of the wheel, and still have enough mounting surface? I don't to be relying on my lug nuts to be holding my wheels centered.
Hopefully the way I explained that makes sense...Comment
the 10s would be non-hubcentric, and are a pain to get lined up. ran a set for awhile on the front of my e30 and couldn't get the vibrations to stop...plus it was difficult to mount the wheels.Ethan, which variant would I need to put on my Apex ARC-8s? They're 17x8 (ET25, 57.1 E30 centerbore), I just want to put a 10mm in the rear, nothing up front.
13mm is a barely noticeable difference width-wise and would bump you up to fully hubcentric. you'll need longer lug bolts as well.
the total would be $70 for the spacers, $24 for the lugs and $12 shipping = $106 shipped.
paypal is labs_8380@yahoo.com, thanks!Comment
no worries, just remove the $24 for the extended lugs and that's your total.Comment
Well, what I was actually getting at is, since I'm running studs and not lug bolts, will mounting and centering the spacers be an issue without them being hubcentric, since I'd rather have the 10mm spacers? Will there be enough of the hub center on the hub itself to fit properly in the centerbore of the wheel?Comment
there will only be 2-3mm of hub flange sticking past the spacer, not enough to give the wheel something to sit on, so it'll still be the lugs centering the wheel. it'll be easier to mount the wheels with the studs, but i'd still recommend the 13s.Comment
damn those adapters are awesome
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
