42 Draft Designs Spacers and Adapters
  • 8380 Labs
    • Oct 2006
    • 2990
    #541
    It's wheel season, shoot me an email at info@8380labs.com and we'll get you sorted with a spacer or adapter setup that meets your needs!
    8380 Laboratories
    M3 Champs Poster
    • zeecky
      • Oct 2015
      • 3
      #542
      Hi, I have style 5's that are 16x7 et20, will the 18mm adapter work on an early e30 chrome bumper.
      • kevmac858
        • Jun 2012
        • 177
        #543
        Originally posted by 8380 Labs
        here's a little tutorial on the mounting of the 4-lug to 5-lug adapters on my very own car.
        wheels are 17x8 et20 F and 17x9 et22 R, adapters are 18mm 4x100 > 5x120 all around.
        install the kidney-shaped adapter plate. tighten it enough that it stays in place, but can still pop into place in the back side of the adapter body - once it's lined up, torque it down.
        Bringing this back up, I recently installed a set of 4x100>5x114.3 adapters and they never addressed how to properly tighten the kidney-shaped plate. It does not sit on the hub so it is hard to really tighten down and get to fit perfectly with the adapter. I tightened it by hand to the best of my abilities while still lining up with the adapter, and then proceeded with the counter-sunk bolts, but wanted to know if there is a "proper" way to install the kidney part.
        Thanks!
        Instagram:@himynameskevin
        Flickr!
        • 8380 Labs
          • Oct 2006
          • 2990
          #544
          I tighten the kidney piece by hand enough that it won't easily shift positions, then place the adapter over it, to get it into the proper position. Once that position is established, I torque the bolt down.
          8380 Laboratories
          M3 Champs Poster
          • kevmac858
            • Jun 2012
            • 177
            #545
            I think I understand what you are talking about. I will have to try that out
            Flickr!
            • 8380 Labs
              • Oct 2006
              • 2990
              #546
              Good deal.
              8380 Laboratories
              M3 Champs Poster
              • 8380 Labs
                • Oct 2006
                • 2990
                #547
                bump.
                8380 Laboratories
                M3 Champs Poster
                • reelizmpro
                  • 9553
                  #548
                  I used a flat head or feeler gauge to wedge in between the hub and the bean to keep it from moving while torquing it down.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • stonea
                    • 2892
                    #549
                    Interested in 18mm 4x100>5x120. Anyone want to buy my 5 lug kit or trade for their spacers?
                    My Garage
                    Feedback
                    Instagram: Stone.Hopkins
                    • florida_dirt
                      • Feb 2013
                      • 497
                      #550
                      The adapters will work for those wheels on your car, yes. You'll have to choose a proper tire size depending on your cars ride height. Your final offset will be et 2 which is really low (wheels will stick out past the fenders)
                      • 8380 Labs
                        • Oct 2006
                        • 2990
                        #551
                        That's a great idea as well.
                        8380 Laboratories
                        M3 Champs Poster
                        • C_x_P
                          • Jul 2014
                          • 64
                          #552
                          Hey guys, I'm trying to run a set of Hartge's 4x100 16x7.5 et. 24. My plan is to run a 12mm or 15mm spacer. What are your thoughts and what length bolts do I need to order.
                          Info would be greatly appreciated! Thanks!
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            #553
                            I'd personally stick with 12mm.
                            The extended lugs are sold in standard lengths based on the width spacer you order, so if you get 12mm spacers the extended lugs will work perfectly for that application. Shoot me an email at info@8380labs.com if you'd like to order, thanks.
                            8380 Laboratories
                            M3 Champs Poster
                            • 8380 Labs
                              • Oct 2006
                              • 2990
                              #554
                              8380 Laboratories
                              M3 Champs Poster
                              • 8380 Labs
                                • Oct 2006
                                • 2990
                                #555
                                ;d
                                8380 Laboratories
                                M3 Champs Poster
