Feeler: Pre-Modified Steering Joints for E36 Rack Swap
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    I'm about to document another steering rack swap on my brother's 89 325i. This time I am going to attempt to make a step by step video to post in the DIY section to better explain the process.
    I have pulled an extra steering joint from a parts car at the local bone yard and I am considering pulling more to modify and sell specifically for this swap. Here is what my modified steering joint will include.
    E30 Steering Joint Shortened by 0.60 - 0.75 inches, the rubber flex disk will be replaced (either stock rubber or aluminum - your choice), and the upper u-joint will be modified to allow the joint to turn at a sharp angle with no rubbing issues.
    Basically you will get a direct drop in steering joint for your E36 steering rack swap. Compatible with the Z3 1.9l, 95 M3, and all other E36 steering racks to be installed in your E30.
    I am also considering replacing the steering flex disk and replacing it with a custom aluminum disk to improve steering response for an extra cost.
    A core charge would be required to keep them in stock. What would be a decent price to charge for them?
    Zionsville Autosport sells them for $195.00
    With enough interest I would be willing to sell them for much less. ($75-$100) + $50 core charge which I will refund once I recieve your old steering joint.
  • browntown
    • Jun 2004
    • 3524
    When you did your writetup originally, didn't it mention something about the column not being collapsable in a crash anymore? Did you find a work around?
    • RobertK
      • Jun 2005
      • 5864
      If you decide to go with an aluminum disk to replace the flex disk then yes you risk the column no longer being collapsable. Of course even the stock flex disk only allows it to collapse so much.
      The aluminum replacement will probably appeal to those who track their car. For daily drivers I would suggest sticking to the stock rubber disk.
      • Van Westervelt
        • 9365
        I would buy one from ya. How about this week? :)
        • der affe
          Technical
          • Dec 2005
          • 8452
          do it i'd be down also
          greg
          • Mot
            45 toting redneck
            • 4018
            for that price I'd be intrested in one aswell.
            • RobertK
              • Jun 2005
              • 5864
              I have to tackle my wife's transmission this week because her throw out bearing is starting to howl and grind.
              I will try to get started on them as soon as possible. Maybe this weekend depending on how the transmission stuff goes.
              I will need additional time to source the aluminum flex disc replacements.
              • Van Westervelt
                • 9365
                I opt for rubber :)
                • Sam Lin
                  • 58
                  I'd be in for 2 if that's with the aluminum discs.
                  Sam
                  • RobertK
                    • Jun 2005
                    • 5864
                    Aluminum discs will cost a little more depending on how much it will cost me to source them.
                    • CarsSuck
                      • Oct 2005
                      • 968
                      let us know about the discs, I will want one for sure.
                      --Will
                      • Van Westervelt
                        • 9365
                        Still rubbers for this homeboy.
                        • Fidhle007
                          I can fly, motherfucker
                          • Oct 2005
                          • 7209
                          Would your modification of the u-joint eliminate the need for enlarging the opening in the firewall?
                          '89 325is S50 Track Montser
                          '04 X5 Daily/Tow Vehicle
                          http://www.avarestoration.com
                          http://www.myspace.com/brendanfiddle
                          Click here if you want to be my zombie slave...
                          http://www.youtube.com/user/Fidhle007
                          • RobertK
                            • Jun 2005
                            • 5864
                            No. That is an issue related to the air bag steering columns in the 90 and 91 E30s. If I could get someone local that wanted to try this swap let me help them out I could use their car to fab up a plate for resale as well.
                            • Fidhle007
                              • Oct 2005
                              • 7209
                              Dammit, I'd be more than willing to be a guinea pig, too bad I'm so far away! My shop just parted a few e30s, I wonder if we still have some steering knuckles around...
