Anyone Experiencing Trans Fluid Loss From The Tilted G260?
  • Lof8
    • Oct 2006
    • 2827
    My trans leaks a bit of fluid from the front seal (I think) during tracking. I get some fluid splatters on the rear of the car after a track day and the fluid level is a little low after a few events. The car did this with the original transmission and its still happening after installing an expensive, freshly rebuilt unit. Its not enough to be a huge concern - just keep an eye on the level.
    I've heard of this from one other guy, but I'm curious if many others have the same issue. I believe its somehow a result of the 20 degree tilt that happens with the 24v swap. Anybody have any thoughts?
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • Lof8
    • Oct 2006
    • 2827
    Apparently this isn't common.
    Just out of curiosity, what is the driveshaft needed when using the e36 trans?
    S50'd
    • Northern
      I like cupcakes & sh!tboxes
      • 5223
      If you use a ZF320, you can use a 328/m3 manual DS, not sure what else.
      Originally posted by priapism
      Originally posted by shameson
      • Wanganstyle
        • 2828
        Try extending your breather?
        the g260 breather is positioned for the SOHC tilt; adding more tilt to it may be the culprit.
        Why not just fit a ZF 5 speed? its cheap and more efficient bearing design; closer gear spacing.
        the ZF gearbox doesn't leak when installed with 24V in e30; 40+hrs racing it all stock.
        • woc
          • 202
          Just drive it on two wheels. problem solved, no leakage. :thankyou:
          • JRKOUPE
            • Dec 2004
            • 3159
            I get some rear valence sut...not sure of the source tho....
            24v/g260 here.
            isnt trans fluid red?...
            geeeez...old thread alert...lol
            • LJ851
              • 7918
              24v/g260 here.
              Trans fluid is red if you have an autotragic, or Redline oil.
              Power steering (ATF) leak?
              Lorin
              The M30 is God's engine.
              • nrubenstein
                • 3148
                Just to be clear, Redline oil is not inherently red. Redline ATF, like most other ATFs, is red.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • LJ851
                  • 7918
                  I agree, the manual trans oil i used from them was red however. At least that's what i remember...
                  Lorin
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    MTL is kinda red, MT90 is more orange. We go through quite a bit of it at the shop and know the colors since my transfer pump hose is clear.
                    john@m20guru.com
                    Links:
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      my post was confusing....I didnt mean my sut was red..lol
                      anyhew..I do get some grimy residue after a day at the track...hmmm
                      my ps lines are tight every track day....
                      I could have a rms drip too... I never considered it being my tilted g260 causing the residue....
                      I cleaned her all up this past month...so now I hope to trace the loss....
                      • LJ851
                        • 7918
                        When you say sut, do you mean soot?
                        Lorin
                        • JRKOUPE
                          • Dec 2004
                          • 3159
                          of course...lol
