s52 vs S54 vs M50 turbo
  • benge100
    • 231
    I know this May have been discussed at length separately but I have started acquiring parts and now need to make a decision, I have acquired a clean low mile 318is that I want to swap. There are many choices to get more power this is what's on my radar.
    Refresh the M42 and throw a turbo on it. 200hp $2000
    I have a nv M50 that I could turbo 3-400 hp approx $4000
    s52 is now a tried and tested route that makes very reliable power and is more or less a plug and play with all of the info on prior swaps out there, on here. 250hp $3500
    s54. Prices are coming down and it seems a lot more affordable. 330 hp out of the box stock, makes a great sound and is sexy. $5-6000
    I have no interest in a V8 at all M30s are a great motor but are a little Stone Age for what I am trying to achieve.
    Posting to get some of your input.
    • 34839
    S54 > all
    turbo? meh - maybe if you like constant tinkering. that shit gets old though. even though the S54 has some high maintenance items, it's a stock production motor that will put down 300+whp with just software and decent headers.
    Second would be an S52. But you're missing like 100hp.. it's a big difference!
    • benge100
      • 231
      Originally posted by nando
      S54 > all
      This is the same conversation I have been having with myself.
      • MC Hammered
        • Jul 2008
        • 2076
        +1 on what Nando said.
        s52 is a lot of fun but an s54 would be all you would ever need for a DD. I wish to have an s54 swapped into my wagon right now, but replacing a perfectly running s52 setup makes no sense even for the extra 100hp.
        I went on a quest for power with a big turbo build on my last car and the tinkering and maintenance made me end up selling her. With an s52/54 it's just start and go.
        My 1989 e30 s52 Touring... this is Betty
        My 1989 325i vert (sold)...this is Nina
        My 1991 M5 (sold)... this is Veronica
        Photo comparison: OEM vs aftermarket windscreen for a convertible
        • Hooffenstein HD
          • Nov 2012
          • 1388
          Euro S50B30.
          • digger
            • Nov 2005
            • 6120
            s54, do it once, do it right
            • ak-
              • 12422
              Considering prices these days s54 or m52 turbo.
              You can make a reliable 24v turbo car - the problem is either people never do everything right the first time around or come up with the assumption that turbo = try and squeeze every HP possible out of the motor, which doesn't usually end well.
              1991 325iS turbo
              • benge100
                • 231
                My main concern with the S54 is I don't see a really good solution for the brakes on a street car. Manual brakes with a BBK seems the way to go but with a ABS delete and manual brakes I don't think will be a good for road driving. Is there a solution that I have not seen yet ??
                With the extra power of the 54 I would like to be able to stop it, my whole goal is to have a nice weekend driver that isn't too wild but is fun to drive I am not a street racer or a track rat kinda guy, I have wanted a swapped e30 for years and only want to do it once and have it a reliable car.
                  • 34839
                  The brakes are solvable, just not with the stock parts. I think the dual MC setup with a BBK makes the most sense. you could also do a hydroboost but it seems like a bunch of extra weight and complication to me. modifying a booster or using a smaller one could also work.
                  I want to do MK60 DSC retrofit (with Mtrack mode), probably some sort of Massive BBK and his pedal bracket with dual MCs. If I can pull it together it should be pretty slick!
                  • HersheySquirts
                    • Apr 2014
                    • 119
                    If you want to make big power go with the 24v T. However if it were my car and I had some loose cash I would do the s52/54 in a heartbeat, especially if it's a daily driver
                    • Wanganstyle
                      • 2828
                      i think the most DD brake setup would actually be using a hydro boost setup from e28 era. Not pretty though and not light weight or full RAZE, but very street oriented.
                      Bmw used hydro boost for intake manifold clearance issues on the e32 750il; all other e32's have moden vacuum boosters.
                      On the e34 the remote mounted booster was done for v8'; this may be to extreme for a s54 e30.
                      • benge100
                        • 231
                        decided and done, I went with a S52....
                        There is so much info on the swap and aftermarket parts re plentiful....
                        I will post a build thread when I get closer to it all happening
                        • bostonbmw
                          • Nov 2004
                          • 429
                          good choice, the s52 is more than enough fun in an e30 and its a hell of a lot less time and money to get working than an S54 would be.
                          • M3avionicstech
                            • Jan 2016
                            • 23
                            Will an e46 m3 instrument clust fit in an e30 m3? Just a thought as I'm missing my cluster.
                              • 34839
                              It fits in the hole, but it doesnt fit cleanly.
