Bosch 044 spec needed
  • goarmy
    • Nov 2011
    • 622
    Hey guys, does anybody know what is the correct amperage for a Bosch 044?
    I kept blowing up my fuse 11 which is a 15amp
    also I don't want to hurt my in-tank fuel pump, did you guys who use this pump had the same issue and what did you do?
  • goarmy
    • Nov 2011
    • 622
    well, I bumped the fuse up to 30amp and now the new bosch 044 pump is dead.. I removed it and benched tested it to make sure and sure enough is dead..
    Is it really a fuse thing or the pump its self
      • 34835
      Defective pump? I don't think the 15a fuse should have been a problem.
      • goarmy
        • Nov 2011
        • 622
        Just ordered another pump, and going to go back to 15amp.. By the way the pump was not to well secure as I found the two small bushing broken and the pump may have been touching the gas tank.
        Would the pump touching the chassis cause something like this?
        • Wanganstyle
          • 2828
          Bosch brand 044 is evil; likes to die mid race weekend
          Try using a different brand of "044" item; tre044 is a direct fit; aem should be also
          • e30 gangsta
            • 3877
            ditch the 044, walbro 450 intank done.
