Relocate IAT sensor?
  • GaryJ
    • Nov 2020
    • 10
    Waiting on a replacement IAT sensor for my OBD1 S52 with an S50 intake manifold. Is it possible to relocate the IAT to the bung of my S52 intake boot?
  • TobyB
    • 5287
    Well sure, anything's possible, even easy.
    But doesn't the IAT only get use for starting? Once the car's on the MAF,
    only the density and volume of air matter for charge metering.
    As in, hot air has less oxygen, but the MAF detects this.
    t
    • Northern
      I like cupcakes & sh!tboxes
      • 5279
      In MS41 (OBD2), IAT is used for ign trim as well, I assume the 413 isn't too different, but then again the closed element OBD1 sensor reacts pretty slowly so it wouldn't surprise me if you're right.
      Relocating the sensor should be fine. It'll adapt to changing temps faster being in the air path like that, but I don't think that would cause any problems.
      Just a matter of adapting the threaded sensor to fit.
      Originally posted by priapism
      Originally posted by shameson
