Slotting the firewall to use the stock brake booster
  • nrubenstein
    • 3148
    If I do this, will I have to do any reworking or repositioning of the pedals/master cylinder?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • mongule
    • Dec 2004
    • 177
    Yea the pedals wont line up anymore with the fork at the end of the booster... Easy to remedy if you trust your welding.
    87 OBDII 328is
    • StereoInstaller1
      GAS
      • 22679
      You taking about basically sliding the booster down, then repositioning the pushrod?
      Closing SOON!
      Thanks for 10 years of fun!
      • Dominic49
        • Feb 2007
        • 1373
        yes slide the booster over
        but bolt the bushrod up to the pedal in a different manner
        • 318isbmw
          • Nov 2005
          • 2843
          That may work, I'm sure it could be done. I've seen a few brake master cylinder kits for hotrods that go under the dash, but I think the time and money going into relocating it all is way more than getting a booster that would work.
          • mongule
            • Dec 2004
            • 177
            We did it last year and pretty much all it involves a bit of welding. I cant remember exactly how it was setup but simple. pretty much just moving the fork by as much as you move the booster.
            87 OBDII 328is
            • 1990m3
              • 1180
              you would also have to rework the brake lines that go to your master cylinder
              • mongule
                • Dec 2004
                • 177
                Yes that also but no big deal.
                All in all its a better idea to just get a 325ix booster.
                87 OBDII 328is
                • lifeiskaos
                  • 1709
                  e30this did this. hopefully he chimes in
                  • Fidhle007
                    I can fly, motherfucker
                    • Oct 2005
                    • 7209
                    How come no one installs the IX booster upside down? Not only does that give enough clearance (offset bracket) but it locates the vacuum line in a much easier to access location rather then being wedged on the frame rail.
                    '89 325is S50 Track Montser
                    '04 X5 Daily/Tow Vehicle
                    http://www.avarestoration.com
                    http://www.myspace.com/brendanfiddle
                    Click here if you want to be my zombie slave...
                    http://www.youtube.com/user/Fidhle007
                    • lifeiskaos
                      • 1709
                      thats what we did...
                      • Kerrath
                        • Jun 2008
                        • 577
                        Yeah, flipping was necessary. I couldn't get the line anything close to fully in. I had it in like halfway, and it gave me vacuum boost for about 3 miles then fell out right before a big hill. Luckily it was almost to where I needed to get it at the time. Thanks to lifeiskaos' idea, it works perfectly now.
                        • e30this
                          • 3580
                          Smart cookie for remembering this...
                          • Mohammed_A
                            • 344
                            i moved my booster closer towards the strut tower and lengthened the pushrod without any welding....
                            • nrubenstein
                              • 3148
                              Well, welding is easy. I guess we'll see which route I go. Thanks for the responses.
