Which Throttle Cable e30 with m50 swap? Pics of setup
  • Enriquez2000
    • Apr 2024
    • 152
    This forum is full of knowledge but I am seeing so much contradicting info on throttle cables. I see e34, e36 and a few others
    Does anyone have a pic of what they have done and the cable they used? Id rather buy once and be done then trial and error.
    Any help appreciated!
  • RenaissanceMan
    • Aug 2004
    • 237
    Keep in mind that a lot of it depends on what brake booster you are running. I originally used an e34 cable when my car had an e21 booster in it and it fit just fine allowing enough clearance between the booster and the throttle body. But the braking feel was horrible so I put a 325ix booster in there which was significantly thicker/wider, so I had much less clearance. I ended up having to modify the cable by bending it into a right angle and doing away with the adjustment threads. I'm planning on doing a much more factory looking modification to it soon and will post some pics. But bottom line is your results will vary based on your setup. Here is a great thread:
    '90 325is/S52
    '76 2002
    '74 2002tii
    '06 325i sedan
    '05 X5 3.0i
    '86 Alfa Spider Veloce
    • Enriquez2000
      • Apr 2024
      • 152
      https://www.r3vlimited.com/board/for...-and-m5x-swaps
      Thanks for replying!... ill be running no booster with a chasebays master.. so booster isnt an issue.
      • Panici
        • Dec 2009
        • 2547
        Does the M50 & M52 use the same throttle body?
        I used the E36 35411163228 for my M52B28. It fits well except that I had to take up some slack with an aftermarket cable end.
        I saw you're planning on using the chasebays master.
        PLEASE do not use the Single circuit master, they are downright dangerous and haven't been used on cars in 50+ years.
        He sells a dual master now by the way.
        • Enriquez2000
          • Apr 2024
          • 152
          Yes its the dual master!
          Im not sure if they are the same TB... do you have a pic by chance? I can take one of mine later
