Only 3 to 4 volts at coil
  • Enriquez2000
    • Apr 2024
    • 152
    Nevermind.. realized you have to check with chasis grounded and im at same voltage as battery...
    Im trying to check coils because Im not getting spark. Following the diagram the green wire shoul be 12v correct? Im only seeing 3 and up to 4 when I crank.
    I assume I should see 12v even without cranking? Why woild I only have partial power?
    Trying to figure out where to check next.
  • TobyB
    • 5286
    I would check
    to find the wiring diagram for your engine and chassis wiring combination.
    t
    because without model data, further speculation requires better spectacles than I sport.
    • Enriquez2000
      • Apr 2024
      • 152
      I have the wiring diagrams. Just not sure why I would see only 4 volts. Its a 1989 model e30 with an m50 swap that I took over
      we start trying to start the BMW E30 drift car with m50 swap
