Help with surging idle
  • i_build
    • Oct 2015
    • 52
    M52 b28 into an 87 325is. I smoke tested it thoroughly and there's no vacuum leaks even confirmed with a can of carb cleaner. Tried new plugs, coil packs to no avail. Swapped a spare TPS in to see if that would change anything but no go. I'm using a 413 red label ECU and I've even tried burning a tune where I bumped up the idle timing to see if that would make anything better but no go. I cleaned the icv a number of times and just ordered a new one just in case. Sometimes if I rev her she settles back to a steady idle however most times she surges. Fuel pressure is 48 PSI at idle which might be a little low but I wouldn't expect that to cause the surging. I'm at a loss and stuck please let me know if you have any ideas. Maf unplugged or plugged the surging persists. New o2 sensor and I placed it 6 inches after merging into my 3 inch exhaust which is about where the heat shield begins underneath. I can't even stomp test it because my check light is no longer working after the swap. Please help thank you in advance.
  • Chilezen
    I weld cats
    • Dec 2013
    • 1940
    Wild, I've had the same issue for years and also gave up. It's not that bad on mine, seems to only happen when it's hot, or like after I get off the freeway. I don't know what it is. Are you saying yours surges all the time at idle, no matter the temp? I'm running OBD2, so at least we can say it's not an ECU thing.
    (I'm also running an M52 in an 87)
    Currently building a badass coffee table
    Random stuff on insta @kevanromero
    • i_build
      • Oct 2015
      • 52
      Exactly. Only after she is warm she starts up with the surging. I was thinking maybe warm up enrichment compensating. I wish I installed my wideband when I was welding in the o2 bung. The new iacv comes in today I'll post back if that gets it but I don't think so.
      • i_build
        • Oct 2015
        • 52
        I'm surprised. New icv fixed my surging. The one that was on it was black and aluminum and the one I purchased was specific to the vin on my engine 1996 328. It was completely aluminum and it didn't fit into the rubber holder on the engine it was wider than the black and aluminum one. I did the rattle tests on the one that came with my engine and it did do that rattle that everyone says to check but either it was messed up internally other ways or that particular one was not the correct one for the vehicle. None the less the idle is now rock steady and returns to rock steady after acceleration when warm. Didn't expect it but I'll take it. Also the outlet side of this all aluminum one is larger than the black and aluminum one.
