AC Adapter
  • ChuckNE
    • Oct 2007
    • 100
    AC Adapter
    Looking to get the AC running on my S50 swap and came across the adapter below. I don't have a clue if this could be made to work on our cars but may be worth a try. Any AC guru's out there that want to tell me if my thoughts are way off base or does anyone know of a similar product. I've called around to several shops in town and have been quoted $150 for custom lines. I am thinking something like this would be much easier and cheaper. Any thoughts or opinions welcomed.
    http://www.nostalgicairparts.com/air...10s20f-593.php
  • Eric Giles
    • 1068
    For that price, I would definitely give it a shot. I am glad you posted this as I have never seen adapters like this before, but they make perfect sense for our applications. I can't recall what size our high and low pressure fittings are, so making sure they are the same as these adapters would be a good idea first.
    Eric Giles
    '20 M2 CS
    '04 M3
    '11 X5 35D
    '87 325is
    '91 325i Sport
    There are few things more expensive than a cheap BMW...
    • Drew325is
      • Oct 2004
      • 520
      Excellent if they fit.
      • dude8383
        • Jan 2005
        • 10387
        werd, nice find!
        • hoveringuy
          • Dec 2005
          • 2749
          That is cool. I did it by having e36 fittings brazed onto my e30 hose which wasn't too bad, either.
          • ChuckNE
            • Oct 2007
            • 100
            Does anyone know the thread size for the stock e30 compressor?
            • Dominic49
              • Feb 2007
              • 1373
              盛世公司『电话』18388987031『微信』—zd996997— 盛世有限公司注册与开户流程-『QQ』—3996637152— 【盛世公司-直属联系方式】【24小时在线的】【公司直属客服】【公司直属开户】
              • dude8383
                • Jan 2005
                • 10387
                wow.
                • ChuckNE
                  • Oct 2007
                  • 100
                  Maybe it would be easier to just use a splicer to connect the 2 lines. They have #10 to #10 splicer but I hear the e36 line is a larger diameter so maybe the #10 to #12 splicer would do the trick and only $3-4 each.
                  • ChuckNE
                    • Oct 2007
                    • 100
                    Bump...Thanks to Dominic for the link to Rays. I ordered 2 spicers and it works perfect. You need a #12 to #10 for the e36 compressor hose (#12) to the e30 return hose from the evap #10. For the compressor to the condenser...I used a line from an e30 318is which had the correct fittings but was long for the swap. I used a #8 to # 8 splicer to shorten this hose. I cut and oriented the hoses and marked them, took them to the local hyraulic line place that had a bubble crimper and I've got game. Grand total under $20 with shipping.
                    • dude8383
                      • Jan 2005
                      • 10387
                      can you get some pics of this? this is really good stuff man, i'm about to mount my compressor for the summer and will likely order this stuff.
                      • Franken30
                        • May 2008
                        • 71
                        Me too (would be grateful to see pics). Do I need a Bently Manual to know what parts I need and, if so, one for the E30 or one for the E36 or both??? Any detail would be appreciated. Thanks -Noob.
                        • hugh jass
                          • 2220
                          would you mind telling us exactly which adapters you used from rays? this is a much cheaper solution than the custom lines from zionsville. thanks!
                          ______________________
                          ex-Chief Operating Officer
                          Blunt Tech Industries
                          West Coast and Pacific Rim
                          • ChuckNE
                            • Oct 2007
                            • 100
                            Part #'s
                            Here are the part #'s and link to the webpages. I will try to post up some pics of the process. Maybe a DIY.
                            #10 to #12 Splicer is Part # 1758. Price $4.48
                            which is found on this page near the bottom:
                            #8 to #8 Splicer is Part # 225500 / 1748. Price is $3.06
                            • flyboyx
                              • 8371
                              that is an interesting and effective solution. i dig it. do you have any trouble with leaks?
                              Gigitty Gigitty!!!!
