Quick and Dirty Question - Do I need E34 oil level switch?
    ....for the 24V swap, or will thh E36 one fit the E34 pan?
    Cheers,
    Lincoln
    Just make a block off plate unless you plan on using the sensor.
    1985 325e 2.8 Turbo VEMS
      you don't need one. I used the euro delete panel, which adds ~.5l to your pan capacity iirc
        I just cut a piece of aluminum, used gasket maker and bolted that bitch to the bottom. No leaks, no problems.
          I'm pretty sure the OEM piece was like ~$5?
            why would you not want the oil level sensor?
              wrong question, why would you want it?
                Part number?
                www.gutenparts.com
                  11131726357 cover lid - list $7.98
                  12611277129 gasket ring - list $2.01
                    Awsome thanks!
                    www.gutenparts.com
                      np I have a cool folder of all my swap crap. It helps in situations like this...
                        I'm using the block off plate too. Factory part that works great and is cheap.
                        Erik
                          Hmmmm. I like having an oil level indicator, just in case of catastrophic failure.
                          Closing SOON!
                          Thanks for 10 years of fun!
                            you won't hear your pan smack the ground?
                              +1
                              doesnt have to be oil pan breaking, it can be a gasket going bad, a seal breaking, a hose bursting, etc. on a long road trip i'd rather know when i need oil than have to check it every time i stop. meh, i know i'll be using one for sure
