If you check your oil every time you get gas, like you should, you will never need that sensor.
Quick and Dirty Question - Do I need E34 oil level switch?
www.gutenparts.com
I am almost postive it will. Try checking realoem and match part numbers.Comment
I made one on a lathe out of 6061, very similar to the one turner sells. It is also recessed into the oil pan pickup, that way if I decide to add an oil temp gauge later on, I can just tap it and fit it for whatever size I need (1/8" or 1/4" NPT).1991 318i Alpine II - S50/5-lug swapped - track carOriginally posted by BillBraskyE36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
1989 325i Cirrusblau - Daily
1970 2500 - Malaga over Grey Cloth
2012 F350 6.7PSDComment
