installing oil pressure and water temps gauges --> ??
  • mck
    • Jan 2007
    • 238
    Originally posted by gregslow318i
    the dme sensor is blue the gauge is brown what I did was just drill and tap the thermostat housing for the water temp
    then I drilled and taped the oil filter housing (part the bolts to the block) for oil temp and for oil psi I got and adapter the goes between the oil psi switch and the filter out let.
    Any pics of the adaptor. I have a mechnical autometer gauge. Do i just run a line from the oil center(Rouge engineering) to the gauge?
    The oil center link
    http://www.rogueengineering.com/Merc...&Category_Code=
    '89' E30 with Euro S50B30
    • shopkeep
      • Oct 2007
      • 94
      ZOMG $110 bucks for the filter lid with the oil senders...
      • MatRacer
        • 562
        On the S50:
        The stock oil sender threads are M12x1.5
        but the coolant temp sender threads are not M12x1.5... I used the stock sender to fabricate an adapter. I cut the connector, drilled ans tapped 1/8 npt...
        E30 now S52
        2008 Suburban LTZ (Family and TT hauler)
        325xiT (Sold)
        • z31maniac
          • 17566
          I don't know, seems like a good price that greatly aids getting an oil temp and oil psi reading.
          I may consider doing that myself now.
          www.gutenparts.com
          • shopkeep
            • Oct 2007
            • 94
            True, i will probably end up getting it as well. It is still $110 though. :/
            • MatRacer
              • 562
              what would be the normal water temps and oil pressure for a S50?
              E30 now S52
              325xiT (Sold)
              • jrdeamicis
                • Nov 2008
                • 956
                The IE cap has ports for senders AND coolers. Way nicer IMO.
                Past Car : E30 S50 6 Speed 5 Lug 3.73
                Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                ___________________________________________
                BNB Designs
                Engine Swaps, Fabrication, Innovation, General Repair
                Richmond CA
                Julian 848-248-8029
                • jrdeamicis
                  • Nov 2008
                  • 956
                  This is an oil cooler thermostat with an 180C thermostat AND it has 3/8"NPT which is the same as the IE CAP.
                  BNB Designs
                  Richmond CA
                  Julian 848-248-8029
                  • mck
                    • Jan 2007
                    • 238
                    Any pics of this one, i can't find it on their site. Have you got a link?
                    • BigD
                      • Jul 2006
                      • 1085
                      I got my oil distribution block off ebay, I think it was like 40 bucks. He taps one hole for the stock switch and whatever you want in the others, so you can have an easier time buying senders in the US. For water temp I simply spliced into the cluster temp signal, the sender is a VDO with the correct resistance range.
                      Pic of block installed:
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        The block is ok, I think its a little sloppy down there though. It is a pretty easy thing to make with a drill press, and a few taps.
                        BNB Designs
                        Richmond CA
                        Julian 848-248-8029
                        • SS350
                          • Jul 2009
                          • 58
                          the "oil center" can be purchased thru UUC as well and is only a BIT more than the oil distribution blocks for S52s, S50's and M50's
                          http://www.bimmerworld.com/html/m505...tion-block.htm
                          TRM makes one as well, but doesnt have provision for stock switch, pressure AND temp...
                          if you search on bimmerforums in the racing sub-section you will find a lot of info and set-ups as well....
                          just bringing this thread back up to top to add info
                          S52 iX conversion --> http://e30tech.com/forum/showthread.php?t=78938 :D
                          • Yage30
                            • 70
                            As I recall, the M50 senders have two different thread sizes. The sender for the DME is M12x1.5, the sender for the gauge is M14x1.5.
                            Seimens VDO makes the temp senders for the M50, and likely most of BMW's other motors as well.
                            I gave a call to VDO a few days ago, since I'm looking into replacing my water temp gauge as well and I wanted to use the stock sender location. the BMW part number for that sender is 12 62 1 747 281. For anyone who was wondering what the VDO part # for the sender, it is 323-805-034-002B.
                            You can find that sender, and many others in this catalog for VDO.
                            I was looking into using the stock sender with an aftermarket VDO gauge, but the temp range and resistance scale does not match. The stock sender maxes out at 130C, whereas the vast majority of senders for VDO max out at 120C, including the sender you buy for most aftermarket gauges.
                            The resistance scale for the stock BMW sender is much higher, with the ohms being about 426 at 90C, while the senders for most 120C sender are 51 ohms at 90C.
                            Hopefully this info helps other out too :)
                            Originally posted by Bene
                            my eta is making a kind of high pitched bird-like sound, like a bunch of retarded cockatiels nesting in the intake manifold.
