May need to bump that idle a bit so that it doesn't stall out when coming to a stop. This isn't usually a problem for me because I clutch in very close to idle (around 1000-1100rpm). I rarely coast to a stop in neutral.
DIY A/C Lines
Originally posted by TeXJ View PostHow does one bump the idle? Do I need to do this with a tune/chip? I'm running obd1 red label ecu(413).IG: deniso_nsi Leave me feedback here
Could try to reach out to Markert and see if he does OBD1 stuff. What chip did the car come with? You could try contacting them...IG: deniso_nsi Leave me feedback here
Originally posted by TeXJ View PostUpdate,
I found a Denso compressor on eBay that had the top plate with the correct fittings, both putting up.RHD OBD2 M50b25 turbo build thread:
http://www.r3vlimited.com/board/showthread.php?t=384800
Originally posted by ba114 View PostLink?
Item title:
96 97 98 99 BMW 328I 325I E36 AC COMPRESSOR DENSO OEM 64528385915
( 182502662566 )
Of course it's no longer available. It was a used part.1990 325is
m52b28
3.73lsd
g260 (1987 325is 5spd tranny)
Yeh havent been able to see any others that look to have the same type of fitting as the original e30/M40 compressor.RHD OBD2 M50b25 turbo build thread:
