Oil level Sensor M50 -> e30
  • Panici
    • Dec 2009
    • 2550
    The solution to wire up the E34 oil level sensor:
    Note that I didn't have the correct connector, so I made due with one that fits the pins.
    Click image for larger version  Name:	2020-05-23 12.09.00.jpg Views:	0 Size:	27.5 KB ID:	9927635
    • shawshankNG
      • Nov 2020
      • 144
      Originally posted by jake5
      Can anyone tell me what pins are what? I.E which is 1, 2 and 3?
      Does anyone know the name of this type of connector?
      Mine is broken but the wires are still intact. Click image for larger version
      1990 325iS
      1990 318iS (sold)
      • mjweimer
        • Dec 2015
        • 648
        It is an AMP housing style connector which can be purchased from Mouser, DigiKey, etc.
        Here is a link to help you get started...click on the data sheet and study the dimensions to see if one of these is a match...otherwise you will need to search a bit.
        MJ
        • shawshankNG
          • Nov 2020
          • 144
          https://www.mouser.com/TE-Connectivi...yvsm2eZ1z0yy6b
          MJ
          Thank you. I found its not the same with most crankshaft sensors connectors so I'm going to have to find it and its specs as this one below didn't fit properly.
          Click image for larger version  Name:	IMG-20201127-WA0021.jpg Views:	0 Size:	64.1 KB ID:	9962309
          ​​​​​https://shop.efiexpress.com/products..._connector_kit
          AMP Junior Power Timer 3 pin male connector kit
          1990 325iS
          1990 318iS (sold)
          • mjweimer
            • Dec 2015
            • 648
            It may just be easier to convert both the male and female to a matching connector. I found a few examples.
            This seller has a good selection and seems to move a lot of parts:
            https://www.ebay.co.uk/itm/Genuine-M...EAAOSw~yNZ5NBl
            As an alternative there is always something a little more unknown:
            Hopefully this helps, if you search for "3 way power timer" you can find some more results.
            MJ
            • e30austin
              • 15382
              for anyone doing this job, that is NOT running a factory oil level sender (in this case, running the TMS oil temp gauge adapter), and wants to turn the dummy light off on the check panel, i have the solution for you...
              the dynamic oil level wire, coming from the c101 (#10, blue wire), needs to be grounded. EXCEPT!!! if you look closely at the Bentley or other wiring diagrams, there is a small inline resistor that needs to be present. if you connect that wire to ground, WITHOUT the resistor, the light will not turn off. the average resistance of an oil level sensor that is in the "full" position, is roughly 998ohms. you need a 1000ohm resistor, in line, before the wire gets grounded to the chassis. with the resistor in place, and the wire securely grounded to the chassis, you should no longer see the oil level dummy light illuminated.
              i searched high and low for an answer to this, and it doesn't seem like anyone has ever documented going to the effort to turn the light off. i hope this helps someone.
              • pcmccutcheon
                • Nov 2018
                • 5
                Austin, I love the post about turning off the idiot light. By chance do you know what size of 1000 ohm resistor, the wattage?
                • Panici
                  • Dec 2009
                  • 2550
                  Standard 1/4watt resistor should be fine.
