Great getrag 260 gods please help me
  • BMW_TUNER
    • Jul 2006
    • 1386
    I just installed my new custom bent linkage and custom made carrier. The car shifts into 2nd and 4th and 3rd very well but I have to push hard to get it into 1st and 5th and it seems the engage halfway and then I push a little harder to get it to engage completly. The tranny was awesome when removed from the m20 so I am stumped. any input is appreciated
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • e30rida
    • 963
    It has to be the custom made carrier or you bent way too much the selector rod.
    • BMW_TUNER
      • Jul 2006
      • 1386
      The carrier is the nice piece made by a board member. If I over bent the rod trying to make up for my 260 on the back of my s50 would it create this problem?
      • 416stroker
        • May 2008
        • 2448
        Why does everyone fucks with there linkage it only rolls a lill bit It hasn't made a difference in my car. 5th doesn't even hit the console so I don't uderstand the reason behind this. And I DD my car.
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • rThor432
          • Feb 2007
          • 3907
          I didnt bend my shift lever at all, no need. I also didnt do anything to modify the aluminum console. I just rotated the selector rod that goes to the back of the transmission by rotating it a few degrees.
          OP, if you bent your shifter I'd start there. Lets see some under-car pictures of the linkage...
          • JGood
            • Jan 2004
            • 7959
            Are you sure the shift lever isn't hitting the trans tunnel? I had to enlarge the hole in the tunnel to get mine to shift and bend the selector rod to have the lever centered in the console.
            They are 20-30 year old cars. People have different booster/exhaust setups, requiring shimming the engine different ways. People also have different trans mounts, moving things around even more. Small variations at one end make a big difference at the other. What works for you might not work for someone else.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • 416stroker
              • May 2008
              • 2448
              ^^ya that's true. I don't see it a problem unless you shim the shit out of the drivers side.
              84 318I Delphin RIP
              89 325 Alpineweiss
              • BMW_TUNER
                • Jul 2006
                • 1386
                No shims on the engine. I am running red tranny mounts. I will pull the boot out tonight and see if anything is hitting the hole. It is not hitting the balancer for sure.
                • Spaz
                  Crazy Canuck
                  • 2276
                  I'm so confused, what did you rotate? And how did you do it?
                  Did you just put the rod back in without any modifications and left the shifter on an angle?
                  -Cam
                  Cam .W '91 325is
                  Spaz's 1991 Alpine White???? S52 Build Thread...
                  • M-technik-3
                    • 18946
                    A picture would solve all the confusion.
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      I cut the rod and tapped one end and welded a bolt onto the other end so that I could get the shifter centered. The shifter is now perfectly centered but I can cleanly engage 1 or 5.
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        my car had a hard time shifting into 2nd in high RPMs and then i did the swap and shabam it shifted just fine into 2nd..... I bent/twisted the aluminum carrier and the selector rod 10 degrees
                        • BMW_TUNER
                          • Jul 2006
                          • 1386
                          So I just strightened my selector rod because it was past 10 degrees and because I had put a bit of a hump in it to clear the balancer. It engages better in 1st and a little better in 5th. I think the one I will receive from mattdk318i will work the best. He has been very helpfull. I tried to make my own but his will be better for sure.
                          • rThor432
                            • Feb 2007
                            • 3907
                            I cut, sleeved, and rotated (10 degrees or so) the selector rod that goes from the base of the shifter to the knuckle on the transmission. The selector rod wouldnt have worked at all without the 10 degree rotation.
                            I was just pointing out that I didnt have to modify the aluminum console. Seems like most people modify those. My shifter sits like a stock one, no odd tilt.
                            • Spaz
                              Crazy Canuck
                              • 2276
                              Ahh thanks for the clarification. :)
                              Cam .W '91 325is
