**Tried** to install the e32 booster??
    It doesn't line up with the stock e30 booster holes in the firewall.
    I tried to install the e32 booster and the two studs are each about a quarter of an inch off from the existing holes in the firewall.
    I know, I'm doing it wrong. What's the trick? Aren't they supposed to line up?
    e32? E21 maybe? or are you using the power assist 7 series setup?
      dewd. you need the bracket in between the e32 booster and the firewall. go get it at a scrap yard.
        It's an e32...
        So there is a bracket that will mate the booster with the e30 firewall?
          wrong booster,need an ix specific one...
          w/ the ix bracket in the back, the push rod would be too short and wont reach your brake pedal assembly-maybe unless you lengthen it w another rod...
          stick w/ the ix specific one,modded e21/porsche 944....
            It's the same part number as the IX booster but doesn't appear to have that middle piece.
              lies.
              get the bracket between the booster and the firewall.
                http://www.r3vlimited.com/board/showthread.php?t=134210
                  or that. depends on how plug and play you want
