S52 cam swap
  • SamE30e
    • Sep 2007
    • 4319
    S52 cam swap
    So it has come to my attention that you can kind of frankenstien a cam setup in a NV M50B25.
    Does this sound right, move the intake cam to the exhaust side and use a S52 exhaust cam on the intake?
    Sam
    1985 325e 2.8 Turbo VEMS
  • White325is
    • Oct 2006
    • 5947
    Yeah you can do that. If you run the S52 cam in the Vanos/Non Vanos M50's you need to either swap to an S52 cam tray and lifters or M52 cam tray and lifters.
    • evangreen
      • Aug 2007
      • 148
      cant you also run the s50 on the intake with out swapping the trays??
      • White325is
        • Oct 2006
        • 5947
        I believe so. But I dont know that for 100% so dont quote me on it.
        • SamE30e
          • Sep 2007
          • 4319
          So I need the S52 lifters, tray and cams to put it into my M50 NV?
          I think you can on a vanos M50. Only reason you can't in the NV is because the S5x engines were vanos.
          Also, what kind of gains can you expect with this hp wise?
          • White325is
            • Oct 2006
            • 5947
            Originally posted by SamE30e
            So I need the S52 lifters, tray and cams to put it into my M50 NV?.
            Well the only motor you dont need to change the trays and lifters in when putting S52 cams in a 24V motor is the M52.
            So yes, you will need a tray and lifters for that cam.
            I dont know what HP gains are but this is a video of my Vanos M50 with S52 cams.
            A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
            • SamE30e
              • Sep 2007
              • 4319
              Nice, I'm sold. Do the M50 NV's have single valve springs, and if so would it be a good idea to put the S50 springs in (if they're doubles)?
              • etexis
                • Apr 2008
                • 191
                cool imma do that then nice e30 White325is
                • SamE30e
                  • Sep 2007
                  • 4319
                  I'm bumping this back up. I want to clear it up.
                  M50NV= double valve springs
                  M50vanos = conical?
                  And to do this swap, I would need a S5x exhaust cam, trays and lifters to put onto the intake side of my M50NV and then move the intake cam to the exhaust?
                  Anybody done this? numbers?
                  • dude8383
                    • Jan 2005
                    • 10387
                    LOL whats taken so long mate? Its been half a year already!
                    • SamE30e
                      • Sep 2007
                      • 4319
                      I want to see how much power I can get out of my NV M50 without getting into internals or boost. I want 190 to 200whp. Plans are Injectors, War chip, larger Maf, underdrives, and cams. I hope that will do it.
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Cams
                        Tuning
                        Headers
                        Injectors
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • SamE30e
                          • Sep 2007
                          • 4319
                          I might go OBDII headers. I have racelands now.
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            200Whp is a lot for a little 2.5.
                            BNB Designs
                            Richmond CA
                            Julian 848-248-8029
                            • SamE30e
                              • Sep 2007
                              • 4319
                              Nooo. I figure I'm putting down around 175whp now which seems to be the norm for M50 NV's with basic bolt on's. Cam's with a tune and all the supporting mods should bring it in the 190whp range if not low 200whp.
                              It's and obtainable goal, if the head is coming off (I need valve stem seals) I can do a thinner Cometic gasket, ARP studs and clean up the ports a bit for a little help.
                              Can anyone confirm the parts needed?
                              And has anyone does the Schrick solid lifter kit that turner has?
