Really Poor Mileage M50 Swap
  • Jason89i
    • Sep 2004
    • 875
    depends on where it broke. i had one crack halfway through the honeycomb.... so only the balk half was displaced . jason
    • E34Dean
      • Aug 2009
      • 19
      COULD be engine coolant temp sensor. for twenty bucks its worth replacing, this really only decreased performance when the engine is warm though. but its worth a shot. what fuel pump are you using? and do you have a hot air intake like most of the people on here
      • Adrian_Visser
        • Jun 2006
        • 2823
        A clogged cat will reduce power and give bad gas mileage and if you know something is loose in your cat doesn't that kind of point to it?
        '89 Alpine S52 with goodies
        • lifeiskaos
          • 1709
          we just found out that something was in his cat yesterday. the car is going to be taken to the exhaust shop friday to get it taken care of.
          • lifeiskaos
            • 1709
            stock e30 fuel pump and indeed a hot air intake
            • Kerrath
              • Jun 2008
              • 577
              Well, the engine is usually warm when I'm driving it. Or do you mean prior to operating temperature or something? The pump is stock and relatively noisy, sounds like all the S10s cruising around. Hot air intake, consisting of a cone filter with silicon intake boot, hanging out next to the coolant reservoir. No shield.
              You were supposed to give me your old heatshield. ;)
                • 34839
                coolant sensor affects fuel at all temperatures, not just cold.
                • lifeiskaos
                  • 1709
                  come get it!
                  • Kerrath
                    • Jun 2008
                    • 577
                    If the CTS is reading too hot, could it cause the DME to run a low idle and rich condition to try and cool off the engine? Kinda the opposite of warm-up mode? I'd be curious about the IAT too, but my engine doesn't have one where the bentley claims it should be, nor anywhere else I can find on the manifold.
                    Got an appt tomorrow to fix my cat issue.
                    Edit: Just stomp tested and got code 1444. The computer therefore isn't aware of what the problem is.
                      • 34839
                      no, not usually
                      IAT is usually in the MAF
                      • Kerrath
                        • Jun 2008
                        • 577
                        Originally posted by nando
                        no, not usually
                        Yeah I read that somewhere else too, but looking in the bentley for E34, it claims that the IAT is in the manifold right next to the throttle body. I've seen versions with and without and assumed the ones with were either for vanos or automatics. The bentley made no clarification that I found though.
                        Thanks.
                        • lifeiskaos
                          • 1709
                          Thanks.
                          it's on the underside of your manifold. remember trying to hook it up when we took your manifold off?
                          nando, it's the obd2 MAF's that have the integrated IAT sensors
                          • Kerrath
                            • Jun 2008
                            • 577
                            No. At any rate, if its there its not visible from looking straight on from the front.
                            • Kerrath
                              • Jun 2008
                              • 577
                              Had my exhaust fixed and got 22mpg this tank, which is a record. 60/216 miles driven before the fixing. So according to my calculations, theoretically, I'll get ~26 miles on my current tank. Then an intake spacer and a heat shield and we'll see where I get.
                              Thanks guys!
                              • Jason89i
                                • Sep 2004
                                • 875
                                Thanks guys!
                                no problem. glad you got it fixed. jason
