Delete power steering?
  • 5mall5nail5
    • 156
    Hey guys - a lot of people say that they delete the power steering when swapping an M50. I am all for this if its manageable. How stiff is the steering with the pump and such gone? Also, do you guys like tie the hoses together or something or what?
  • M3Fan
    • Sep 2009
    • 16
    My power steering pump went a while back and I can't stand the amount of steering effort is required for around the town driving. Definitely not recommended on a DD in my opinion. I can't wait to get the new pump in.
    • JGood
      • Jan 2004
      • 7959
      I'd also not recommend it for a daily. I had it out of my e30 with a 95 m3 (3.0-turn) rack, and it was to the point where I was wearing down the leather on the steering wheel. My hands would turn black and the leather would crumble, because it required so much force. I also took p/s out of my track car with a stock rack. A little better, but it was much better with it installed. I wouldn't recommend removing it to anyone for a daily driver.
      I just looped a single line and sealed it that way. There are also plates for sale that block off the ports, some member of this forum made them. You can fill it with grease or oil.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • erik325i
        • Jan 2005
        • 3567
        I removed the power steering in my M3 track car with a z3 rack. I bought the aluminum plate made by "silence" that caps off the rack. It feels great on the track, but I probably wouldn't want to do it on a street car.
        Erik
        • Lazr111
          • May 2007
          • 340
          No power steering on my dd (stock rack), and i guess i've gotten used to it... its not that bad imo.
          If life passes you by... Downshift.
          • 1990m3
            • 1180
            not that bad IMHO either. Surprisingly it's easier to steer the car when I have the 17s on than when I have the 15s on. It's a good setup for me. I run an e30 m3 rack and drive around on the street a little, mostly track work. I prefer the steering feel without the ps pump on the track...
            Its really not that intolerable. Sure, more steering effort, but as long as you're rolling 5mph or more it's no biggie
            • mentaleeill
              • 850
              Jon, i have no power steering in mine and it's never a problem. i cut the ends off my hoses and welded them together, it kinda looks like an 8. you gotta leave a little stub on each end and rotate them to face eachother when bolted up, or just have jay make you a block. i drilled one of the banjos and threaded a zerk in it, a couple pumps of grease and it's smooth as butter. you definately need to loop the system somehow though.
              deleting the power steering and running with a bad pump or no belt are two different things. it takes alot more effort if the pump is still there.
              • etxxz
                • Feb 2006
                • 2085
                still rocking p.s. on my track car..
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
                • zav3n
                  Curious George!
                  • Mar 2007
                  • 223
                  wtf no way in hell. i love my power steering.. and i really dont think you can feel the 3 hp gained..
                  • MattM
                    • Apr 2009
                    • 931
                    if its a DD then no point, its going to save you maybe abourt 30lbs, which for a daily driver you will never notice... if its a dedicated track car then its up to you...
                    Full Build Thread Here
                    • rThor432
                      • Feb 2007
                      • 3907
                      I took the power steering out of my car because I prefer it that way. I did it mostly because I wanted to drop the front end weight after putting the heavier motor in and keep the car closer to 50/50. Doesnt bother me at all and I dont even think about the fact that it doesnt have power steering until threads like this pop up. As long as I'm rolling my E30 on 225/15's feels the same as my E36 M3 with power steering on 245/17's--- so if you are moving there is hardly a difference.
                      I made a couple of vented fittings so that I could use the standard bolts with crush washers.
                      It's really up to you though. If it's something you are into, go for it. If not, dont. If you dont have a reason to justify it, dont. One friend that drove my car had so much trouble turning the wheel when the car was parked that I actually laughed. It definitely isnt for everybody..
                      • lifeiskaos
                        • 1709
                        i like not having power steering on my DD... so it takes a little more effort to park, but anything over 5mph and i cant even notice
                        • Wh33lhop
                          • 11705
                          I'm going to give manual steering a shot when I do the M50 swap, but I don't necessarily plan on leaving it like that.
                          How many of you manual steering guys have an E36 rack and parallel park a lot?
                          paint sucks
                            • 37828
                            I have no power steering on 2 of 3 cars. Love it!!
                            If you have a rack other than the stock E30 rack, i can see it being a definite problem.
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • rThor432
                              • Feb 2007
                              • 3907
                              I dont have an E36 rack, but I do parallel park a lot.
