just unpacked my ecu - blue label 413?
  • 416stroker
    • May 2008
    • 2448
    #31
    Its should be your starter. The pin outs are correct 18-18. Not all pins are used.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • matt
      • 3732
      #32
      Battery?
      • Lof8
        • Oct 2006
        • 2827
        #33
        Originally posted by matt
        Battery?
        had the battery on the charger for a day and a half and I had lots of accessories working. I'll look at the starter. The starter wiring seemed almost fool proof...maybe thats where my problem is.
        check my starter thread please:
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • Jean
          • 18228
          #34
          Can you test the starter on its own by connecting it directly to the battery etc?
          • gregslow318i
            • Sep 2007
            • 1918
            #35
            do you have a main power lead from the bat to the starter?
            yes I have tried and tested this adapter on a 87 year e30 and it worked.
            looking for a e30m50 swap harness adapter pm me $150 shipped
            email nitroman12@gmail.com
            • Lof8
              • Oct 2006
              • 2827
              #36
              See any problems here, Greg?
              thanks
              S50'd
              • Lof8
                • Oct 2006
                • 2827
                #37
                there are pin location differences in both connections, but I don't know if they are significant or not.
                S50'd
                • Lof8
                  • Oct 2006
                  • 2827
                  #38
                  My area of focus for the next time I get to the car is starter wiring.
                  Greg has confirmed that the harness looks correct.
                  Out of curiosity - why do some of the gaps between pins not line up?
                  S50'd
                  • Jean
                    • 18228
                    #39
                    You have a 25pin C101 on one hand and a 20pin adapter?
                    Or are just using two different images for reference? My 91 m30b35 harness had the same type of 25 pin c101, and an earlier one had a 20 pin.
                    Obviously a 20 pin c101 adapter won't work if you are trying to use a 25 pin harness. You'll need an adapter for a 25 pin c101 or a 20 pin harness.
                    Or do you have a picture of each end of the adapter in both pics? Probably this :) It's TOO EARLY lol
                    I would test the starter on it's own next.
                    thanks
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      #40
                      jean he is using one of my x20 to c101 adapters.....or a 25 pin (e36 late e34) to e30 20pin
                      • Jean
                        • 18228
                        #41
                        Yeah that's what I figured as well, hence the "It's TOO EARLY" comment ;)
                        • Lof8
                          • Oct 2006
                          • 2827
                          #42
                          Greg, I certainly believe you that the adapter is tested as working and the pictures look functional.
                          Could you explain why the pins and holes in the harnesses/adapter do not all line up exactly. Are some of the pins/wires unused in the swap?
                          thanks
                          The top picture seems to show an exact male to female relationship, but if you look closely, it is not.
                          S50'd
                          • Jean
                            • 18228
                            #43
                            Not all pins are usually used, some are air bag/ traction control stuff etc.
                            • gregslow318i
                              • Sep 2007
                              • 1918
                              #44
                              thanks
                              well on some of the early model e30 (like yours) they did not have alot of the other accesorys that the late models did like abs, road speed signals, under load, srs, ect.
                              essentially there are only 3 pins need to start a m50 from the adapter and they are all the same between all c101's the rest of the stuff is dependent on the year and model ( 318, 325 m3 ect)
                              the pins are pin 13-13 for the fuel pump, pin 7-21 dme power and pin 18-18 for the starter (12v switched)
                              have you tried jumping the starter yet?
                              • Lof8
                                • Oct 2006
                                • 2827
                                #45
                                I have not been able to work on the car since the day I started this thread. I will post an update when I am able to do so.
                                Thanks for the assistance guys:)
                                My car has abs btw.
                                S50'd
