just unpacked my ecu - blue label 413?
  • Jean
    • 18228
    Checked/replaced main/fuel pump relays and double checked wiring already? Sorry, I had a red 413 a few days ago but already shipped it out.
    • Uber E30
      • 1409
      sounds like EWS to me, what chip do you have in the ECU and have you sniped the EWS wire?
      -Alex
      • Lof8
        • Oct 2006
        • 2827
        Actually, I can hear the fuel pump working and I get gas from the fuel line too. Wiring looks good too. There is absolutely nothing from the starter when the key is turned.
        I'll have to get in there again and do some diagnosing. Its just a bummer 'cause I don't get down to work on the car too often (1/2 hour away). I was hoping to fire it up today.
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • Lof8
          • Oct 2006
          • 2827
          Its a stock chip as far as I know. I'm not familiar with the ews wire and have not snipped it. I was under the impression a chip was needed to delete ews.
          S50'd
          • matt
            • 3731
            The ECU/chip/EWS has NOTHING to do with your starter.
            Check your wiring.
            • Lof8
              • Oct 2006
              • 2827
              Is it possible to just turn the engine over via the starter with no dme hooked up?
              S50'd
              • Lof8
                • Oct 2006
                • 2827
                Check your wiring.
                you answered it before I asked :)
                I used the s50 solenoid with the m20 starter. Maybe my problem is in the wiring at the starter. I'll check there.
                thanks
                S50'd
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Yeah, Programa is a re manufacturer that World-Pac sells a lot of.
                  • gregslow318i
                    • Sep 2007
                    • 1918
                    hmm that adapter I made you was tested on my own car and worked... so you are saying that the motor will not even turn over when you engage it with the key in the crank position???
                    looking for a e30m50 swap harness adapter pm me $150 shipped
                    email nitroman12@gmail.com
                    • Lof8
                      • Oct 2006
                      • 2827
                      yep, exactly right. are there any extra pins in the adapter plug? It seemed when I was plugging it in that the adapter had a few more than the e30 chassis harness. Should I look a little closer at this?
                      S50'd
                      • Spinning Tires
                        • Feb 2007
                        • 283
                        I had the same problem with my m30 swap. I forgot to put the ground strap on the engine. Check that out
                        First: 1984 318i
                        Second: 1987 325
                        Third: 1987 325is
                        Current: 1990 325i (Soon To Be 335i)
                          • 37829
                          Car should crank fine with or without the DME even installed.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • gregslow318i
                            • Sep 2007
                            • 1918
                            the crank signal is pin # 18 on both the e36 side and the e30 side. but the adapter is know working as once again it was tried and worked on my own car and if you look at the etm for you car is shows the same pin for your year e30...I am thinking ether you starter is hooked up wrong or its a bad starter.
                            • Lof8
                              • Oct 2006
                              • 2827
                              Hey Greg, my car is an '87 325i. Is yours the same? When connecting the adapter, I noticed that there were some vacant holes in both the adapter and the chassis harness. These vacant holes did not match up exactly in all cases. I figured that some of the pins were unnecessary or something of the sort. I'll get some pics up tonight.
                              S50'd
                              • Lof8
                                • Oct 2006
                                • 2827
                                engine is grounded and has been turned over by hand with a wrench (its not frozen or internally damaged).
                                if an ews dme does not stop the starter from cranking, I'm looking at the adapter and starter wiring as possible problem areas.
                                S50'd
