I am considering a swap and I am trying to figure out what type of donor motor to hunt down. What are the pros and cons of the OBD 1 versus OBD2? Thanks
How much easier to do an OBD 1 swap than OBD2?
Tags: None
well i will give you credit for asking this question in the 24V swap section, but with questions like this no one will take you seriously. you gotta search THIS particular section of the forum to get your answers...
type something as simple as "obd" and search for the term in the 24v thread.IG: deniso_nsi Leave me feedback here
I will give it a try, but I was hoping to save a bunch of time. Hopefully, there will be some good threads in the search.Comment
to be quite honest, you'll learn a lot more by searching. summaries of this kind of stuff just won't cut it. each option has its pluses and minuses.IG: deniso_nsi Leave me feedback here
obd1 = more support, more documentation, more tuning options, easier wiring
obd2 = better ECU, theft prevention (EWS), expensive (4 o2 sensors! etc)
obd1 is quite a bit easier in my opinion.Comment
Well, one thing I like about my stock m20 is its simplicity and low cost of maint. So, maybe the obd1 is the way to go.Comment
obd1 for simplicity, price and power for starters. imho.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
You can get OBD-II tunes that delete the air pump, back O2 sensors, EWS...........Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Keeping whatever comes with the engine will be the easiest.
I would go OBD2 route simply because the engines are newer,lower mileage and well easier to find (for me).
OBD2 will be more expensive due to the need for removal of EWS and what was mentioned. But its a decent trade-off depending on mileage and availability of engines near you.
Tuning is no longer a big deal although OBD1 still has many more options.
Some say the ultimate is s52 or m52 converted to obd1.
Depending on future plans, this may or may not apply to you.87 OBDII 328isComment
...and anyone who retains the OBD-II should delete these things. There werent as many options for retaining OBD-II when I started my swap, so the OBD-I conversion seemed ideal. But, I had to buy all new sensors and such because all of the old used ones were in poor shape (especially knock sensors..). So that bumped up my cost considerably. The OBD-II harness and sensors I removed from my 70k motor were in excellent shape.
If I had the options that are out there now, I would have kept the motor OBD-II. Above all else, I much prefer the OBD-II diagnostic interface although OBD-I isnt really that bad..Comment
