Bearing knock?
  • madjurgen
    • May 2005
    • 1203
    Pull a coil off, rev to ~3k, check for noise, repeat for each cylinder. If the noise goes away for one of the cylinders, now you know you spun that bearing. Worked for me when I spun a bearing on my m20.
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
    • jahnaboi
      • Oct 2006
      • 1742
      Lets jot down his symptoms and notes:
      - He replaced the rod bearings some km's ago. (Possibly not enough oil clearance which caused the bearing to fail or incorrect amount of torque for the bolts)
      - Is not as bad cold compared to when warmed up
      - Increases loudness as rpms rises.
      Sadly enough it seems like to me your rod bearings are out. It would probably be wise NOT to start your motor anymore. Rather, pull the pan like someone suggested and check it out.
      SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • Mohammed_A
        • 344
        Originally posted by SpecM
        a rod knock will get MUCH louder with higher rpms
        then i doubt its a rod knock coz this sound is constant, spoke to my mechanic yesterday, he heard it and said it most probably worn small end bushes....
        • Mohammed_A
          • 344
          Originally posted by nando
          how is your oil pressure?
          i assume the pressure is fine, dont have a gauge or anything but no warning light coming on... when i built the motor i did replace the oil pump
          • Mohammed_A
            • 344
            this is a good idea, gonna try this as well..... just confused why the noise would go away when the coil is unplugged???? isnt the rod still turning on the crank?
            • madjurgen
              • May 2005
              • 1203
              Youre only going to hear bearing knock if there's combustion present.
                • 34835
                I would get a gauge on there. the dash light doesn't tell you anything, it doesn't even come on until 7psi or something like that.
                • Mohammed_A
                  • 344
                  thanks
                  • MIKe30
                    • Sep 2006
                    • 2334
                    scarey stuff. Good luck dude
                    • 5KWattson
                      • Apr 2009
                      • 809
                      i did that to check what cyl was knockin on my m20 when i got it as well
                      "God created turbo lag to give V8's a chance" Taylor D.
                      • Mohammed_A
                        • 344
                        okay so i've done this but the noise is still there when testing each of the cylinders, it never went away at all.....
                        What next??
                        • SpecM
                          • Oct 2005
                          • 4531
                          maybe its tappet rattle?
                          Euro s50's have mechanical lifters, right?
                          1989 cirrisblau-metallic 325i
                          • Mohammed_A
                            • 344
                            i think i should strip off the tappet cover and check clearances, but does not sound like it... euro s50 have shims.. and buckets, i suppose they are called mechanical lifters
                            • Mohammed_A
                              • 344
                              any ideas
                              • dranttna
                                • 127
                                alittle quicker way to find the noise than going and buying a stethascope(yeah its miss spelled.. i think) is just hold a screwdriver up to your ear and point it around on the engine at differant angles, it works really well, youll most likely be able to find which cylinder its on too. just my 2cents
                                325es/24v's/20psi/meth injection/
